Horn Question
Discussion in 'General Maverick/Comet' started by J.Hope, Dec 1, 2003.
  1. Greg
    Greg Member
    Lincoln IL
    1973 Maverick
    If it was mine I would just disconnect the horn. It would seem that the problem is either the horn or the wire going to it.
    Just my 2 cents.
  2. BluesCityMav
    BluesCityMav Member
    Memphis, Tn.
    1977 ford maverick,1978 granada ess factory 4 speed, soon to have a 460 transplant,Muahahahahaha!!!!
    horn blows
    The car's horn is possessed, take a chicken foot, a bottle of rum, and naked lady into the car, drink the rum, let the lady rub the steering wheel...or what ever, lol..then toss the chicken foot out the window...dang that horn.lol...j/k
    Russell likes this.
  3. bmcdaniel
    :bananaman :clap: :bananaman
  4. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    mabbe herbie changed cars lol he got tired of the volks wagon and wanted a real car:D
  5. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    J.Hope, I had a simular experience a while back when I went to North Carolina on vacation. The horn started blowing in the middle of the night for no reason. The only thing we could figure out was the temperature change outside (28 degrees) caused something to contract just enough to make contact and blow the horn. Does it blow in both hot and cold ambient temperatures? If thats not it I would go straight to that new steering wheel you just installed a double check your horn contact clearances.
  6. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    Maybe you tightened the three bolts that hold the steering wheel to the adapter too tight?? if thats the type of steering wheel??? Im not too sure. When i put on the grant wheel, i put them too tight and it would arch and blow the horn.
    -Todd:)
  7. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    It definitely is not a module going bad...the on-board electronics in the Mav are just not sophisticated enough for anything like that! :D
    Also, Mavs do not use any kind of horn relay like some cars do..12v runs up to the steering wheel and is switched by the switch in the center pad. Any "shorting" of the wires along the way would likely just create sparks and/or a blown fuse. I am thinking that there is something going on in the steering column that causes 12v to flow across the pins under the wheel only when you happen to be turning the key...that is the place I would start looking for the problem...
    Does this problem ONLY happen when you are starting (cranking) the car, and does the horn work OK otherwise?
  8. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    Yes, the horn is fine it works when it is supposed to. It only beeps the three times when I'm cranking it up.
  9. 71gold
    just when cranking, maybe we have a pattern here. let's not do the crank and try the starter and see if it does it then.:rolleyes: :rolleyes: ...frank...:D :D :D
  10. J.Hope
    J.Hope Member
    Walker La.
    1976 Maverick
    Let me add that it only does it once. If I was turn off the car after it starts and re start it. The horn doesn't blow?
  11. 71gold
    static electricity, yes that's it...frank...
  12. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    My first thought was an aftermarket alarm.
    If that's not it, I'd search the web for a budget-priced Exorcist.
  13. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
