How can I make the 302 motor faster in my '71 Comet?
Discussion in 'Technical' started by lika, Nov 27, 2008.
  1. 69GT
    69GT Member
    Fresno
    72 Grabber Maverick.
    HHHHmmm. Yes it does seem like it's a little low. I cant think of anything else aside from the motor being 37 years old and it was 33 with about 94K miles when I modded it.
    Ok... The run down:
    Holley 650 DP
    Ported Windsor heads 1.94/1.60
    Air Gap dual plane.
    Electric ignition (MSD)
    Longtube headers. 2 1/2 exhaust H pipe. Flowmasters..
    Old school cam research cam. 108 lobe .510 int .515 exhaust. 224/232 Dur... I think I smell the culprit :)
    3.70s in the 9"
    T-5
    I vote for the cam. Yours is a roller probably far more efficient.
    My 331 has a Comp 274HR. Just gotta put that damn thing in.
  2. bmcdaniel
    Yep, bet it's the cam.
  3. justin has a 74
    kentucky
    so are you saying our cam is damping our hp???
  4. PaulS
    I think it is the cause for your lack of economy.
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    That's friggin awesome!
    My old 306/TL 4 speed/4.11s with 700 DP got less than 10!
    The cam was 228/235 on 110*... awesome grind BTW!
    Just couldn't expect it to pull before 2500 rpms, but the WR toploader and 4.11s made 2500 rpms come FAST.
  6. lika
    lika Señor Comet
    IA
    comet 71
    I have a 1971 Comet. I'm working on rebuilding the body. I'd also like to make the motor faster if possible. It is the regular 302 motor, automatic. Does anyone have any tips?:drive:
    Thank you
    Thank you all for the advice.
    Here is a picture of my motor 302
    that i want to make better.
    Thank you for the help!
  7. Bryant
    follow the tips that answered you question the first time
  8. lika
    lika Señor Comet
    IA
    comet 71
    I just realized that I wrote "standard" but my car is really automatic.
    please just let me know if any of your tips won't work on an automatic.
    sorry for the comfusion
    thanks again.:Handshake
    [ame="http://www.youtube.com/watch?v=idkFpJ54WYQ&feature=related"][/ame]
  9. Bryant
    they will all work
  10. t.ramsey
    t.ramsey Member
    austin,tx
    both
    I gave mine a good tune up, advanced the timing to 12 degrees, put on a 500 Holley 2 barrel, and dual exhaust. With a stock tranny and 2.79 gears, it would chirp going into 2nd gear at about 45 mph.
  11. PaulS
    By themselves headers will not increase power much but if you add a 4 barrel manifold and carb and a mild cam it can make a big difference.
  12. lika
    lika Señor Comet
    IA
    comet 71
    re:
    So what can i do with this carburetor?
    is going to work​
    [/ATTACH][/ATTACH]
  13. justin has a 74
    kentucky
    reminds me of someone i use to know....ME!
    if your still in high school, take the auto classes, ive spent about 3 weeks in it so far and i learned alot
  14. Bryant
    i think those headers have oval ports. got to be carefull when ordering headers that you get the right port shape.
  15. PaulS
    Your carb is a typical emissions style carb. You would get more out of a carb for a 69 351W 2 bbl than from the one you have. The difference is that the accelerator pump has a bleed hole back into the bowl on yours, it is jetted lean enough that you could get a lean surge at freeway speeds. The 69 carb has no bleed hole and it has jets that are about two sizes larger. It won't hurt fuel economy (it might improve) and drivability is way better.
