how do i jack up my back end of the maverick
Discussion in 'Technical' started by justin has a 74, Aug 12, 2009.
  1. blugene
    Tubb it :)
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    to much money for a 18 year old kid going to college
  3. blugene
    Sound like the wrong car to have then...
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    no just the wrong tires. the grabber got me through my poorest years but let me advance. a car payment would have buried me.
  5. Bryant
    dont do the longer shackels. they put tomuch leverage on the frame and can cause it to twist.
  6. JHodges
    JHodges thumper
    Dora Alabama
    hell yeah:chirp::burnout:
  7. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    i bought my car with adjustable shackles and never had a problem that i know of. and i drive my car like the devils after me.:evilsmile:burnout:
  8. maverick4925
    maverick4925 Rust, Rust and more Rust
    Amelia, Ohio
    1970 Ford Maverick
    whats wrong with the shackles? i'm in the process of doing it myself. left side down, right side to go.
  9. 1973Maverick357
    Cookeville TN
    I have shackles on mine no problem.. But im ditching them because i dont like the look of them.
  10. sierra grabber
    northern nevada
    my money is on what bryant is saying because he knows his stuff.... you can strengthen the springs and roll the lips of the fenders and backspace\squeeze in rims, but if you do that and still rub you have to downsize or put in tubs to not break things...
  11. Bryant
    ive only heard of the shackels causing the frame to twist. that is from people on this board. it does make sence. your are multipling the leverage that gets applyed to the frame in turns. also when ever i see long shackels, the leafs are always flat or even arched the wrong way. i had a freind who bought a 69 mustang and it had shackels on it so the huge tires that stuck out 2 inches on each side. they still would rub over any bump. the springs were in a reverse arch with the shackels. so he go new wheels and we cut the shackels down to stock length. we thought that we would have to get new springs but when the shackels were stock length the springs were arching the normal way again. i dont know why but it tells me that the shackels put to much load on the springs.
    the best way ive seen to correctly lift the rear of our cars is to build or have a custom leaf spring built. facelessnumber's research has shown that ford e series vans have leaf springs that fit in our cars. so if you dont want to spend the big bucks you can go junk yarding and get some of those to work with. you can mix and match the different leafs from both the mav and the van to achive what you want. rember that if you lift the rear, your shocks may end up being too short. ultimatly its your car and you have every right to do what you want to it.
  12. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    What size tires are you trying to run?
  13. justin has a 74
    kentucky
    275 something:rolleyes:
    btw i got shackles today and installed them.. i do like them alot.. they are about 3 inches longer than stock:ignore:
  14. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    how wide are your rims? i have 10in wide on the rear and 255 tire it rubs a little if i hit a big bump on just one side of the car
  15. justin has a 74
    kentucky
    i think they are 8 inch rims??? lol i know the tire is to big... mabey 10...
    does the tire happen to rub on the drivers side???
