How do I.......
Discussion in 'Technical' started by ptpdub, Apr 26, 2020.
  1. ptpdub
    ptpdub Member
    canada Sk.
    How do you degrees the outside of a super Duper crazy greasy engine? This one is from the early 60s and it’s never been out. I would like to repaint it after the rebuild and need a very clean block. I will be unable to hottank it.
  2. TeeEl
    TeeEl Senior Member
    Colorado
    SuperClean in tbe foaming spray bottle.
    And buy, borrow, or rent a power washer...
  3. fastfords
    fastfords Member
    East Tennessee
    70 Maverick, 71 Comet GT, 72 Sprint, 75 Comet, Maverick Stallion
    I use Easy-off oven cleaner and a pressure-washer. Just spray it down let it set for about 30min then hit with a pressure-washer.
    TeeEl likes this.
  4. TeeEl
    TeeEl Senior Member
    Colorado
    Yeah, oven cleaner is good for the really nasty areas...
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Both solutions mentioned are on point, just make sure to wear safety glasses and a face shield, you don't want that stuff in your eyes!
    TeeEl likes this.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Yep. I wore safety glasses the last time I used it on my current project. I actually used the oven cleaner on the frame & K-member, and the SuperClean on the rest of the engine compartment (engine out)...
  7. ptpdub
    ptpdub Member
    canada Sk.
    thanks all, I will do exactly that. face shield and all.
  8. yellow75
    Tillamook Oregon
    Make sure to cover distributor and carb so no water gets into them and it works best if you scrape away the big chunks first then the cleaner of you choice can get to the grime that is stuck on the block. If you have access to a steam cleaner it is far better than a pressure washer but not that many places have them unless it is a industrial shop like a mill or truck repair shop
