How important is a Thermostat?
Discussion in 'Technical' started by BrianB, Dec 17, 2010.
  1. BrianB
    BrianB Member
    1973 Maverick
    so what about running a 195 on a stock 302? and at what temp does it "overheat"?
  2. rthomas771
    I had my 289 up to 230 before I noticed it without having a problem.
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    just make sure to use coolant and have a fan shroud
    i had my mav up to 230 and i could notice a difference in the way it was running/power then i stopped to get a bite to eat and when sitting it got up to 250 and was hard to start ((( i didn't have a fan shroud thats why it did that ))) and i think it hit like 104 that day
    got a heating problem get the taurus fan and it wont happen again
    i got the 3 core aluminum radiator and taurus fan on low and have no problem's
  4. Earl Branham
    Lugoff, SC
    I use a 160 degree stat, and have a Taurus fan set up. Car runs at about 170 degrees around town, but on the highway, it runs at 180-185 and I have never had a problem.
  5. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    It depends on where you live a 160 or 170 wont defrost your windsheild in cold Utah winters I always use 190 or 195.
  6. BrianB
    BrianB Member
    1973 Maverick
    im in southern california so in the summers it gets pretty hot.. is 195 to high then?
  7. coutangman
    coutangman Member
    Charlotte, NC
    If you want to run a 180 degree thermostat, ask the person waiting on you at Autozone for one. They have a selection in their screen that says otional thermostat, which will have the 180 listed. You probably got some inexperienced person that didn't know this was there. I usuallu run 180's in my older engines and on the temp gauage, they usually run 190 on the road. Engines run better when they are in the 190's range.
    Jim
  8. jumper
    jumper Member
    CEDAR PARK TEXAS
    1970 MAVERICK
    yes you do
    moister, sludge ,no heat,wear on the engine when not at operating temp over my 35 years working on cars i have found the factory gets it right 98.9 % of the time assuming you want reliability. $8.00 bucks and a little labor back in business:)
  9. darren
  10. BrianB
    BrianB Member
    1973 Maverick
    so heres a question, at what temp does friction reduce?
  11. Bryant
    its just not that simple.
    when a motor is desgined they consider the heat expansion rates of the different metals used in the motor. they try to make it so when the motor is at operating temp every thing is at its ideal tolerrnce.
    most of the friction in a motor is controled with the oil system. the weight of the oil depends on the tolerances used in the motor. the tighter the tolerance the thiner or lighter weight oil is needed to get where it needs to go.
  12. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    I live in PHX AZ, I run 195's in all my windsors.
    I get worried when i start seeing 220
    Good radiator, good cap, good fan, good coolant, good airflow, good hoses, good water pump, 195 stat.......... no worries
  13. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    I run a 180 in mine,
  14. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    I really think anything in the 180-195 range is fine. I just see alot of people using a lower t-stat to try and cover up another cooling problem like a band aid. I think being able to "control" your desired coolant temperature is much more important than the stats opening temp.
  15. injectedmav
    injectedmav Member
    Georgia
    Darren is absolutely correct. coolant moving too fast through the engine and radiator will not pick up enough heat from the engine as it rushes through the coolant jackets and it won't give up the heat if it moves through the radiator too fast. I have used an old thermostat with the center punched out as a restrictor in a pinch. If you don't need heat in So-Cal then just run a robertshaw high flow 160 deg. I have a 195 in mine now with a stock water pump and 3row radiator and with air conditioner blowing full blast I might see 210 in the heat of the summer on a 100 deg day with high humidity (90+ %). Make sure your coolant to water mix doesn't exceed 50/50. If freezing isn't an issue, run 25% coolant to 75% water and a little water wetter and you should be good if your cooling system is sound. I am using an electric fan from a 95 crown vic (condenser fan) with no engine driven fan at all.
