How much does it cost to build a Dart long block . . .
Discussion in 'General Maverick/Comet' started by mashori, Nov 8, 2011.
  1. american opel
    american opel Member
    ashtabula
    1972 grabber 1967 opel kadett
  2. bmcdaniel
    Yeah $3500 is a little on the stupid side but Dart blocks require more machine work to make them useable. Lifter bores need finished and sometimes aligned, decks need finished, sometimes even the oil pan rails. And then, if you're going to a +.125" overbore... You can usually figure $700-$900 dollars over the price of the bare block.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Man this is good information. I figure 600hp should be streetable, of course I don't know that for sure but that's my guess. I really would like to add some sort of a power adder to get it in the 1000 hp range, really just for bragging rights and it seems like turbo is the most streetable but nitrous might not be a bad idea either. I mean I could add a 400hp shot couldn't I?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I would guess around $15,000 to have a complete engine ready for a power adder.
  5. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    For the streetability part look up murder nova on youtube,it's a buddy here in okcs car. F3 procharger over 1700hp and he drives it ALOT,when hes just drivin around he runs pump gas and just keeps it outta boost.
  6. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I've been thinking about this for a while myself. I'd love to have 500hp to the rear wheels meaning I need 600 at the crank. It needs to be lightweight with lots of low end torque for pulling out of the corners. It needs to be pump gas friendly and cruise down the interstate getting 20+ MPG. Oh.... and I need it on a budget. No LS motors allowed. Blowers, turbos, superchargers, all add weight and cost big money.
    The standard 427 crate motor builds from most any of the shops will get close on everything (550ish HP) but the price especially when you start looking at EFI. But then again. Their dyno numbers are also flawed in that they are not taking into acct the parasitic loss of crank driven accessories like AC, Water, Alt, Pwr steering...
    Im now making my goal a little more realistic with trying to get the power in the RPM range I can use it most.
    So... what are you looking to do with this motor. Its pricey to get 1 to do it all.
  7. maverick75
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I couldn't find the parts list for the short blocks that dart sells. Are those pretty stout?
  9. Streamliner
    Streamliner Member
  10. mercgt73
  11. maverick75
    They don't really list the specs on the parts on the "small" 347 smallblock.
    But on the "Big" 427 small block it has all the good stuff:
  12. olerodder
    olerodder Member
    NorCal
    WOW!, 1000HP..............now that is some serious $$$$$$$$$$$$$
    I know you have already thought about this, but with those small tires out back I would think you'd have to drive with an egg between your lead foot and gas pedal.
    Will your current suspension handle that kind of HP.
    Have you got some 13" front disc's or bigger in the front and at least 11" in the rear?
    If I were going to shoot for that kind of HP I'd want to have the complete block blue printed.............Line Hone'd, decked to the crank centerline, lifter bores clearanced, internal balancing and clearanced to nano gram, as the blocks really need some attention before they can take that kind of punishment. I would be putting a Bryant or Crower crank along with not just your standard "Made in China" H beam rods, maybe Cunningham or Crower and some really good pistons, not your garden variety $500 set, and while you are at it have someone make a special roller cam that will make real HP but still be streetable from stop light to stop light, some really stout push rods and along with some Jesel shaft mounted rockers.
    I think 1000hp can easily be made but I would run injection and a turbo.
    Then ofcourse you will need the trans to take that HP.......................my guess is $15k for the motor and another $3k for the trans.
    I am already in my refreshen'd 408 $4k, and that is just taking care of CHP's mistakes when the "crate motor" went together some 11 years ago.
    "Cubic inches make Big HP, and it takes Cubic bucks to make the HP" IMHO
  13. bmcdaniel
    I can see the rear quarter panels wrinkling now... LOL
  14. maverick75
    The replacement for displacement is forced induction!
  15. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Mines a 447 and on a 300 shot it made 950 at the rear tires. That's with a lazy nitrous cam and a super-tight nitrous converter.
