How much hp will my 331 make?
Discussion in 'Technical' started by mashori, Mar 20, 2010.
  1. cheezno6
    cheezno6 Member
    Central ILLINOID
    Man the unboosted #s are good for such a low comp ratio, but damn you gotta run is some scary RPMs to take full advantage of that blower. Is that cam even suppose to make power up that high? It's also kinda weird that the volumetric ef peaks so far below the peak HP
  2. maverick75
    that's because the AFR's are bad ass(y)
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm actually curious what the car will do on the dyno . . . I'll take the car to the dyno shop after the 331 is in and then i'll dyno it again with the supercharger
  4. cheezno6
    cheezno6 Member
    Central ILLINOID
    Hurry up Man! :) I wanna build a 331 and need some ideas (no ubber $ blower though OS tunnel ram for me) :tiphat:
  5. cheezno6
    cheezno6 Member
    Central ILLINOID
    Thats impressive with 185s
    Hey could you run a 331 with the same cam 10:1 and Eldelbrock Victor JR heads through your DD?
  6. maverick75
    what cfm carb? 600? 650? 750? FI?
  7. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    your gonna have some block trouble gettin around 550hp and some rpm,are you planning on running a main girdle?
  8. scooper77515
    For what it is worth, my dyno2000 HP rating was right at 400, and my actual dyno number was 330. So if mine is typical of how dyno2000 works, then it would be safe to subtract 15-20% from the dnyo2000 numbers and use that as a real-world flywheel estimate.
    I didn't just plug in numbers, I actually entered flow numbers for my heads, entered specific cam info, etc, to get my dyno2000 readout.
    So, that being said, dyno2000 is estimating your engine to pump out around 530 hp.
    I would expect that blower to pull those torque numbers up earlier in real life. Those seem kinda low for a blown engine.
  9. cheezno6
    cheezno6 Member
    Central ILLINOID
    a total of 900 cfm
  10. cheezno6
    cheezno6 Member
    Central ILLINOID
    If the peak HP is at 7,500 then you better use a world or dart block, and I'd still use a girdle with them. 7,500 rpm with 9psi of boost could cause catostophic faliure
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm gonna go with 700cfm
  12. cheezno6
    cheezno6 Member
    Central ILLINOID
    Why not 900? (post #24) I'll be running 2-450 cfm Holleys
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    it's gonna be a daily driver so I'm not worried about taking it up that high. I'll have to mess around with the cam to change the power curve down a little
  14. maverick75
    do the same here:yup:
    just changed it to 700cfm...and updated the pics
  15. cheezno6
    cheezno6 Member
    Central ILLINOID
    I have heard the FMS E cam works well with blowers as does some of the trick flow offerings
