How tall is your floor auto shifter
Discussion in 'General Maverick/Comet' started by smegnl, Dec 23, 2019.
  1. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    So how tall is your auto floor shifter? Im looking to put one in with a bench seat. I dont want one with a big bottom console type box. A simple rubber boot would be nice. Post a pic of you of your floor shifter. especially if you have a bench seat.
  2. Powerband
    Powerband Member
    NY's \H/
    Even with a manual valve body, a simple manual shift boot looks like it would work. Wth a T5 a Bench seat is still viable. .Typical vendors usually list a small and large 'Hurst" type shifter boot. Large @ 9 X 8 " makes it simple.
    https://www.summitracing.com/parts/huu-1147494/overview/
    have fn
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thanks is that an auto? You know how tall?
  4. TeeEl
    TeeEl Senior Member
    Colorado
    Bucket seats are your friends...
  5. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    True, but I really like the bench. Just need a shifter that is tall enough so Im not bending over to shift into drive.
  6. Hotrock
    Munroe Falls, Ohio
    Are you positive you do not want a mini console? Does your shifter have a reverse lock out? Have your neutral safety switch and back up lights been addressed? Both of these issues are resolved in my console.
    71gold likes this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    which one is that?
  8. Hotrock
    Munroe Falls, Ohio
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  10. Hotrock
    Munroe Falls, Ohio
    I'm not familiar with that particular B&M shifter. On the Summit Racing website owners give it good ratings and the description indicates there is a neutral safety switch and back up light switch.
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    did all 70 mavs come with a neutral safety switch? Even if they were stick from the factory?
  12. Krazy Comet
    I dunno but it really doesn't make a difference, at worse connect switch between present wiring and trigger post on solenoid...
    AFAIK all dash harnesses, auto or stick are same.. Without neutral safety, under dash there should be a plug with a jumper in it... If auto plug connects to neutral safety sw. Since 1970 was first year Ford used neutral safety for sticks, 69½ may or may not have one..
    My 4-speed Cobra has no neutral safety, while automatic Fairlane does, I know harnesses are same.
    Hotrock and smegnl like this.
