how to make my maverick handle better...
Discussion in 'Technical' started by random hero, Jul 12, 2009.
  1. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    yes it does touch the HEI
  2. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    it may fit nicer with a 302 idk if it sits any lower
  3. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
    btw guys i just put new rims and shocks all round my car and it handles 10x better. i used KYB gr2 for a 85 nissan pu for the rear and summit adjustable drag racing shocks for the front.
  4. Joe Dirt
    I got to drive my car today with the 16" wheels and lower profile tires handling is def improved
  5. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    What strut bushings do you guys use? I want to replace mine and was thinking about these. Are they worth the extra money. I am planning on replacing my tie rod ends at the same time with some moogs also. Let me know. Thanks...
    http://www.summitracing.com/parts/MOG-K8157/
  6. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    I use PST poly bushings...work great.
  7. Bryant
    if you use the poly bushings on the strut rods, they will break after a while. the poly bushings are too stiff and cause the strut rod to flex as it swings up and down with the controle arm, fatiguing it to the point of brakeing. the brakeage usually occures on the freeway and the results are not pretty. those moog one will work nicely.
  8. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
  9. LukeDuke
    LukeDuke Member
    Oklahoma City
    1976 Comet
  10. Positively Ralf
    Yonkers, NY
    1974 Maverick
  11. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    help please..
    Are there places that you recommend poly bushings? I'm new at this and about to order all of the bushings for a 71 maverick with a 4.1L 250 and A/C (don't know if that matters)...is there anywhere to get a list for all of the bushings on my car so that I don't leave any out when I order? Also, are there any other quirks you know about bushings besides not using poly on the strut rods?
  12. Bryant
    the only other places in the front end that can use them are the lower controle arms, the sway bar end links and sway bar bushings. they are fine in these locations, although the lower controle arms busings are so small that there is not much to be gained here and you have to replace the entire lower controle arm just to replace the ball joints. so get the swaybar bushings and do the rest of the front end with stock replacement stuff. moog is usually considered the best replaments for stock stuff. you can get polyurithane for the rear leaf spring bushings and you will notice a improvement in the cars handling with those.
  13. CaptainComet
    App,
    Here is a link to the kit that I used ... PST Polygraphite bushing and front end rebuild kit. You get the lower arms fully assembled. You have to install the bushings in the uppers, re-using the sleeves. It comes with tie rod ends ( I believe I had to specify ones for a later disc-brake car because I did that swap at the time, and the ends are different between drum and disc).
    http://www.p-s-t.com/pc-2232-96-ford-maverick-1970-77.aspx
    Nice kit ... these bushings are quiet.
    I did get poly strut rod bushings too and installed them ... broke the drivers side rod about 6 months later. Fortunately, it let go at 5 mph going over a speed bump. Ripped the steering wheel right out of my hands. Would have been ugly at speed... head on into traffic going the other way. Get the Moogs for the rod bushings. :thumbs2:
  14. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    by any chance do you know what years?
  15. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
