how to make my maverick handle better...
Discussion in 'Technical' started by random hero, Jul 12, 2009.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    old thread i know.. but, if you want monotube gas shocks all around
    fronts would be kyb-gas a just for mavericks
    rears will be monroe sensa track for a 85 nissan 720 p/u
    mustang front 620 springs with one coil cut
    double roller spring perch for front..
    pst leafs with reverse eye 4 leafs.. with around 150lbs spring rate?
    pst swaybars
    wider rims/tires for w/e diameter rim you like..
    anyone know if the roller idler arm or any v8 early mustang idler armwill work with mav steering?
  2. vinceking001
    vinceking001 Gearmonkey
    Nashville, TN
    1975 Ford Maverick
    I read in a resto-mod book (don't have it handy, or I'd quote the title) that for the control arms, it's best to use high quality (like Moog) control arm bushings and poly for the sway bar. The argument was that unless it's a purpose built track car, poly is a little too stiff, which hurts drivability and road comfort and poly dries out and squeaks WAAYYY too easily. They do make greasable poly bushings which help (but don't eliminate) this problem. the poly for the sway bar bushings and end links is a definite go since they really help with body roll our cars are notorious for. I whole-heartedly agree with this mentality. High quality rubber replacement bushings for ride quality, poly for the sway bar. This combination has worked wonderfully for me on several cars I've restored as well as 2 mavs I've owned.
  3. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    I bought a 7/8 inch swat bar for the rear of mine from NPD national parts depot. I believe it was for a 65-67 mustang, I can check. If you call them just don't tell them it's for a maverick cuz they won't sell it to you. My friend has a couple mavericks and this is my second one and we had to go back weeks later and talk to a different guy and say we had mustangs. I think it was $150-175
  4. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Can you post some pics of that setup? I'd be interested to know how close it gets to the shock on the right side.
  5. 1MTMIND
    1MTMIND Member
    California
    73 Maverick/Comet
    I had no real fitment problems at all. You do have to drill holes for the end links in the frame that's no big deal though. It is close to the breather vent for the rearend but that's it. Will takes pictures later, at work now. Made a huge difference. I want a big front sway bar but don't know what fits. You'll also have to cut off the excess bolts that attach it to the rearend cuz they will hit the under carriage area. But once again no big deal. No need for 2-3 inches of bolt past the nut anyway.
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    Interesting. I was planning to get the Addco rear swaybar kit for Mavericks but there's no way it would be compatible with my lowering blocks, which I pretty much need so that the leaf springs will clear my rear disc brakes. I'm hoping maybe this alternate kit might be the ticket.
  7. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    you could clock your backing plates so the bolt misses the leaf spring than add the sway bar on. thats what I got on my car, explorer rear discs and I have the rear swaybar...
  8. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    I did the leaf replacement from an econoline van, rear sway bar, 15x8 front and rear wheels however the front tires are narrower. 205/60 r15 front 225/60r15 rear. Whatever you do, do not use squared tires in the front it will kill your suspension and alignment, in my opinion these cars are not meant for squared tires. And some Damn good shocks! You'll be cruising like a champ.
  9. Bryant
    what are squared tires. all the tires ive ever seen are round.
  10. bmcdaniel
    Can you imagine the contact patch to the road with squared tires...
  11. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Does any one have some picks of there rear sway bar set up. i just redid the front suspension and it feel good going down the road. I also put in new leaf springs and rear shocks but the back end still need something.
  12. eds73mav302
    eds73mav302 Member
    pomona ca, 91767
    maverick
    Square edge tires, obviously tires are round, I didn't know I had to get primal here.
  13. Bryant
    i still dont quite understand about square edged tires. are you referring to low profile tires that have a rigid side wall or something else.
  14. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    I replaced just about all the front end pieces, poly swaybar links and 225/60-15s vs the 205/75-14s up front . I don't have any numbers but the car definitely handles better with minimal body roll.
  15. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I think he's talking about what I picture as stock tires like off my dads 48 Chev. Or similar sidewall design as a BFG A/T that I have on my truck.. I guess you could call them a squared? Sidewall as they do have a crisp edge and are not rounded over into the tread
