How to remove lifters from 250 engine
Discussion in 'Technical' started by jerrymal, Jul 28, 2011.
  1. maverick75
    They should be hydraulic, IIRC only the early 6s had solid lifters, they also came with adjustable rockers. Later on they went to non adjustable ones.
  2. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    it may be froze up or stuck, try a strong magnet , if it is really crudded up spray a little pb blaster around it and let it sit overnight, that is why i use a magnet if its an old engine and has been sitting for a while ,its hard to tell what may be stuck when you start to pull it apart
  3. jerrymal
    jerrymal jerry
    Brownsville tx
    1973 maverick
    Ok, finally removed the lifters, wd40 help, so now I'm going to start installing everything back . Thanks alot for all your help
  4. predfan2001
    Coat hanger hammered flat on the end and bent over 3/8" from the tip. Works everytime.
