How to remove steering wheel without puller?
Discussion in 'Technical' started by will8069, Dec 23, 2009.
  1. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I made my own puller too. Used a steel thing and some bolts and nuts. It was a one time thing and broke as i removed it from the wheel afterward but I had to do it. The splines on the column were/are shredded.
  2. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Give a shot at the loosening the nut, moderate pulling and tapping first and maybe you'll be one of the ones it worked for. If not, head to autozone and do the deposit thing. Who knows, maybe it's off by now.:clap:
  3. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    Yup, same here. SO MUCH EASIER
  4. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
  5. Jeff S
    Jeff S Member
    NoVA
    none
    = cracked dash or chipped out sleeve from missed hits or swinging the hammer too far back...because you cant hammer if off from the front...lol
  6. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I agree on getting the puller. It was worth my money of buying one a long time ago.
    If your worried about the money then just go to the parts store, give them cash, go out in the parking lot and do the wheel swap. Then return it.
    This way you don't have to make two trips and you won't chance loosing it or never taking it back
  7. rthomas771
    We all like to work on cars and we need tools to do this so why not buy a puller. If you get your money back then a few years down the road you will have to pay double for a puller that probably is made cheaper than the one you bought a few years ago. I have specially tools in my tool chest that I bought when I was a teenager that I though I’d never use again and I find myself using them all the time.
    Ronald Hopkins and BBMS18 like this.
  8. bLaH_hA
    bLaH_hA Member
    jacksonville, fl
    72 mav grabber(sold), 1970 maverick grabber clone
    Well tried renting a puller but ended up snapping the bolt on the pulley any ideas what went wrong. I followed the instructions on the box but that bastard wasn't moving
  9. CaptainComet
    Did you loosen the big nut first? ... other than that I would say the splines are corroded and may need some PB Blaster or the like to loosen them up.
    Some wheels are loose enough, especially if they have ever been pulled off before and reinstalled, and others are going to fight you. I have a small puller that goes with me for every junkyard run. I have yet to use it, but don't want to regret not having it that one day I will need it.
  10. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    It doesn't always help, but when I have a particularly stuck one I put some tension on the tool and try rocking the wheel. Sometimes this breaks them loose. When you have the added leverage to the rim of the wheel it gives you a little bit more persuasion. But you do have to be careful...too much force and you can bend or crack the wheel itself. I've also smacked the center of the column (where you just took off the big nut) with a hammer. But I don't recall that trick ever working and only used it on columns I wasn't planning on reusing (read: junk yard vehicles).
  11. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You don't pound on the wheel it's self, you apply pressure to the wheel (towards you) and you hit the shaft. Same idea with ball joints, the pressure and vibration breaks the friction grip. This video gives the idea but I push up on the wheel with my knees when I do it. If you don't you can damage parts like the bearing in the column.
    You can also get the puller applying pressure on the wheel and hit the pusher bolt, this can get them apart as well.
  12. maveruss1
    maveruss1 '70 5.0 C-4
    Moreno Valley, Ca.
    1970 2dr.Maverick, 2005 Mustang
    Auto parts stores will rent pullers. You pay the price of the tool and when you return it they give you back all your money. But if you don't return it, you've just bought the tool. Try it, it's easy.
  13. Moneymaker 1
    Panama City Florida
    Wow 6 year old thread, rent the puller!
  14. maveruss1
    Moreno Valley, Ca.
    OTE="Moneymaker 1, post: 1045121, member: 12991"]Wow 6 year old thread, rent the puller![/QUOTE
    WOW, your right, 6 years ago! That's one heavy duty steering wheel. I didn't know that thread was so old, otherwise I wouldn't have replied. I feel like a goofball. I'll check on the date next time. There should be a time period where it automatically deletes itself.
  15. Moneymaker 1
    Panama City Florida
    I think a lot of us have been guilty of the same thing, I know I have lol.
