How to remove the turn signal cam
Discussion in 'General Maverick/Comet' started by William623, Jul 11, 2016.
  1. William623
    Orlando
    1973 ford maverick grabber
    I am trying to remove the turn signal from my steering column. I removed the three screws, then the turn signal lever. The turn signal module does not want to pull out am I missing something? This is for a 73 if that matters.
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Most of the time you cannot get the wiring harness out of the steering column without either removing the plug or taking the column apart. There is also a harness retainer on the bottom side of the column you have to disconnect.
  3. Craig Selvey
    It would help to unplug it on the other end.
  4. William623
    Orlando
    ...wow should have looked at it more. So unplug the harness from the bottom and it should then pull out?
  5. Craig Selvey
    The plug is also clipped onto a metal support bracket. Need to get it off of that as well.
  6. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    How do you snake the new harness down?
  7. yellow75
    Tillamook Oregon
    Tape a wire to it and gently feed it through, would be easier if you taped the wire to the old one when you pull it out
    Paul Masson and Krazy Comet like this.
