How to replace rear shocks. 1970
Discussion in 'Technical' started by Bumble1970, May 8, 2020.
  1. Bumble1970
    Bumble1970 Member
    Rhode island
    70 Ford Maverick grabber 6 cyl
    Hi, looked a few articles but wanted to check on the location of the top bolts for the rear shocks. I thought they would be in the trunk but they’re not so I’m assuming they’re under the back seat. ? Do I have to remove the bottom of the seat and the back of the seat?
  2. Acornridgeman
    Acornridgeman MCCI Wisconsin State Rep Moderator
    Wisconsin
    Everything is accessed from under the car. The top of the shock is a horizontal bolt / stud that goes through a bracket that is bolted to the body. The bottom is a stud on the shock that goes through a plate / bracket that is attached to the leaf spring by the u-bolts for the leaf spring. 1970 did not use staggered shocks so the plates and brackets are different from other years.
    If you need pictures let me know.
  3. Bumble1970
    Bumble1970 Member
    Rhode island
    Ok thanks, so I have to remove the rear seats to get get to the top nut, correct?
  4. Acornridgeman
    Wisconsin
    No - everything should be under the car. Unless there is something about that 7 1/4 rear of yours I'm not aware of.
    Many Fords of that era did have access plugs found inside the trunk to get at shocks - but I have never pulled a rear seat to get at shocks - ever. I'll go take a picture of my 70 right now for you.
  5. Acornridgeman
    Wisconsin
    If your car doesn't have a top shock mount like this ........... look for a rubber access plug in the trunk.
    My June built Grabber does have an 8".
  6. Bumble1970
    Bumble1970 Member
    Rhode island
    Ahhh. Ok. Thanks Eric!
  7. Bumble1970
    Bumble1970 Member
    Rhode island
    Just replaced both rear shocks. It was simple (once you gave me the information). :). It’s crazy how all the nuts just screw off, they’re not rusted to the bolts. Thanks again!
    71gold, RMiller and Acornridgeman like this.
  8. Acornridgeman
    Wisconsin
    Cool ........... glad you were able to get it done
    Always nice when fasteners are not a solid piece of rusted junk.
    BBMS18 likes this.
  9. Danielmaverick
    Danielmaverick Member
    Earth
    1970 ford maverick
    Would you mind sending pictures? I have a 1970 however the driver side rear shock is on the rear side of the axle and the there are two brackets with a spacer. Can I just rotate the the plate under the leaf springs to get rid of the staggered shocks.
  10. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    (n)That just takes all the fun out of it!
  11. Craig Selvey
    One can't rotate the plate under the leaf spring. Won't work that way. Plus it pushes the shock out toward the tire.
  12. Acornridgeman
    Wisconsin
    Sorry, just saw your post. I can get a picture later - right now the car is still in storage. 38 degrees with light snow /rain mix today. Still early in our "car season"
