How will my motor respond on the dyno?
Discussion in 'Technical' started by olerodder, Mar 24, 2012.
  1. Joe Dirt
    Back running, proceeding with break in now, the oil pump had locked up (crank driven)
  2. darren
    YEAH ME!!!! I used all my years of automotive training and expertise to come up with those figures. :16suspect
    Gotta admit just pulled those numbers out of my A#$. LOL. :huh::)
    That engines way out of my league.
    Real nice numbers even if you where expecting a bit more. Im sure you'll be happy when it hits the track and you get it set up.
  3. maverick75
    you should still be able to run your 10's with that power :thumbs2:
  4. olerodder
    olerodder Member
    NorCal
    You know, I did run a 9.801 with the old motor so maybe the chassis is setup better than I thought, because just from the dyno pulls this motor although a little lower CR and slightly different cam looks to be more repsonsive than the old motor..................so as long as I can consistently get into the low 10's I'll be happy...............maybe I need to loose a little weight also.............and the new Global West front end should give the front end more articulation........................we will see.
  5. yellow75
    Tillamook Oregon
    Well just punching your numbers in on a couple of those calculator programs that judge from weight of car and flywheel hp they say anywhere from 9.37 to 9.75 so even with some fudge factor thrown in I dont think 10.s will be hard to achieve, more like staying in the 10.s will be harder.
    I guess we will know shortly though :thumbs2:
  6. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Nice job! (y)
  7. olerodder
    olerodder Member
    NorCal
  8. Stefan
    Montreal, QC
    Congratulations to Darren on getting the closest estimate. Olerodder, thank you for your generous support :)
