Howdy- first question, HELP!
Discussion in 'New Members Forum' started by hotrodbabe, Jun 13, 2014.
  1. blugene
    I agree on poorly re-manufactured starters being out there. I have also gone through a bunch in the past with my ex wife's LTDII.
  2. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  3. kirkds00
    kirkds00 Member
    Milford Ohio
    1973 Mercury Comet, 1969 Ford Galaxie
    Thanks to all for the help and Welcomes!
  4. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    I would like to add that ford flywheels will over time burr up on the teeth, and cause a motor lock up! The flywheel can be pre grinded at a angle for easier mesh-engagement. Your problem sounds like a rare factory machining problem. You could use a dial indicator on the flywheel run out---rotation. You should remove the trans. and install only a bell housing with the starter mounted on the engine. Have a sloted viewing window on the bell housing for inspection while cranking to check starter engagement --- aglinement. These are processes of elimination, I wish you luck and wisdom. This is why I still drive old Fords :grouphug::tiphat: If needed I will elaborate further. Happy fathers Day
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Any idea if the transmission or the engine was ever out of the car?
    I had my head up my #$$ one time when I was installing my engine. I bolted the flex plate to the converter and started her up. Nasty grinding noise and the starter was locked against the ring gear.
    Turned out that I did not align the converter drain plug with the hole in the flex plate. This warped the flex plate.
    Remove the inspection plate and rotate the engine. Look for a warped or cracked flex plate. Take a look at the ring gear too.
    Micah
