Hub Centric Wheels
Discussion in 'Wheels and Tires' started by NewMaverickGuy, Jun 13, 2018.
  1. NewMaverickGuy
    NewMaverickGuy Member
    Birmingham, AL
    1970 Ford Maverick
    with a 70 mav 4 lug, do new wheels need to slip on to the hub snuggly or could I use wheels that have a larger center bore? Seems like a bad idea considering that the studs would be the only thing holding it. i wanted to go with Cragar Quick Tricks, but the hole is a lot bigger than the hub. Other than that, they are the same dimensions as stock for the most part.
  2. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I'm searching all over the place for wheels to work on my car and ive had no luck
  3. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    Heres my reason for new wheels. The pits are rather deep: 20180613_153556.jpg
  4. 71gold
    a larger center bore won't hurt, the lug nut seats/centers the rim.
  5. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    So the studs would be strong enough on their own? That would be great
    71gold likes this.
  6. Krazy Comet
    Aftermarket wheels assume so.. The center opening is almost always as large the hub of a particular pattern will allow.
    The '70-up Ford hubs are larger than '69-prev, nowhere has Ford stated not to use later wheels on earlier vehicles. Of course it's obvious the early wheels will not fit '70-up.
  7. NewMaverickGuy
    Birmingham, AL
    1970 Ford Maverick
    I went ahead and got some Cragar Quick Tricks 14x6
