Hvac switch install
Discussion in 'General Maverick/Comet' started by scs, Mar 7, 2015.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Can anyone tell me how to get the hvac control switch in. It just does not seem to fit anyway. If the silver knobs come off, it would be easy, but they don't seem removable. Thanks image.jpg
  2. mercgt73
    mercgt73 Member
    The silver knobs pull off. Then you can remove the trim plate, but be careful, they are notorious for snapping the pins off.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Steve,
    What is that "Cobra" garbage at the bottom? Is it hiding some screws that someone drilled to mount the cover?
    Micah
  4. Krazy Comet
    Cobra GARBAGE??!!
    It is one of the stick on plates used as identifiers for the '69 Fairlane Cobra(note my cars)...
  5. scs
    scs Member
    Prescott wisconsin
    Thanks, but I got it figured out without any help... finally! It goes in from the back, not the front. I'm not sure why I didn't think of it earlier #%$?@#. Anyway, there is no way those silver knobs are coming off without breaking them (maybe I'll try some heat). I do need to replace the panel eventually, so I need them to come off. Tom, do you want that Cobra stick on, I don't want it.
  6. 71gold
    knobs just pull off...:yup:
  7. 71Mavrk
    71Mavrk Member
    Nevada
    Tom,
    I mean that only in the fact that some people like to stick "Cobra" on cars that never were.
    Steve,
    Those knobs sometimes would pop off over the years. Someone may have glued them on. You might have to sacrafice them to get them off.
    When I got my dash together, those unpainted control arms looked ugly. I slipped some heat shrink over them before I put the knobs on. It looked a little cleaner.
    Micah
  8. scs
    scs Member
    Prescott wisconsin
    Thanks for the info (yes, they appear to be glued on, they are not falling off). The heat shrink sounds like a good idea. Do you know of any new replacement knobs out there?
  9. scs
    scs Member
    Prescott wisconsin
    Never mind, I see Melvin's has them. Off they come. P/N C9ZZ18519A. How about an HVAC control panel, without A/C, I don't see that at Melvins.
  10. 71Mavrk
    71Mavrk Member
    Nevada
  11. Craig Selvey
    You have got to get the knobs off or you will never get it in. You have to get the heater bezel off.
  12. scs
    scs Member
    Prescott wisconsin
    Thanks, this confirms my 2 hours of unsuccessfully trying every option from the front. But, I did finally get it in from the backside with bezel and knobs on. I do have almost all of my dash disassembled and I'm sure that made it possible from the back.
  13. Craig Selvey
    Wow......didn't think it was possible.
