Hybrid Hood
Discussion in 'Cosmetic' started by mavgrabber01, Feb 7, 2005.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have seen many modded grabber hoods...
    Not one ever looked good to me.
    Not that I care about the hoods, they just look too cobbled up. "Busy" was a good word someone posted.
    You could always order up a fiberglass grabber hood and go for it... It's your car. :huh:
    I have never seen a teardrop between the scoops of a grabber hood. You can order a fiberglass hood from the factory with any scoop they carry pre-installed. They usually charge the price of the hood, scoop, and about 100 for combining them.
    Dave
  2. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    I agree, The grabber hood looks great the way it is.
  3. stmanser
    Davenport, Iowa
    just cowl induct it.....nice and clean and functional and then high angle of the windshield is great for a cowl induction hood.
    im getting the 2-3 inch cowl hood as soon as i start on the painting process
  4. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Same subject-different question- anybody ever drilled out the fake grills on the scoops and made them functional? Not cut- just drilled out between the lines to look like real expanded metal?
  5. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    The performance gain you would get from making the grabber hood scoops functional is somewhere between non-existant and really really really small. I know that may upset some people, but it really is the truth. It's just simple fluid mechanics, there is very little airflow near the surface of the hood due to all the friction from the air flowing over the sheet metal. This is why you really only see the super large scoops that are raised up 6-12" off the surface of the hood on serious drag cars.
    If you want a performance gain, run some smooth, large diameter, straight as possible ducting up to the front of the car somewhere between the valance and the bottom of the hood lip. The optimum place to put these vents would be at a place called the stagnation point. The stagnation point differs from car to car and you would have to put a mav in a wind tunnel to figure out exactly where it is. But it's definitely in the region I described, and any point in that area is 10 times better than using the stock grabber scoops. This isn't always easy though because of space constraints, extra equipment like A/C stuff, etc.
  6. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    I did , but only because I was realy board at the time :coco: .
  7. rayzorsharp
    I agree with mavman on this. The ones on my blue car are drilled but it's only because they were drilled by a previous owner. :smash: The only thing I think it acomplishes is getting my engine wet if it happens to rain on it, which it seldom sees now but it does happen.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I agree with the Pontiac comparison. They are a bit too ornamental.
    Stick the Grabber hood in the corner and modify a stock hood if
    you want to be different. I can't imagine it ever looking better than
    it does stock.
    Seth
  9. ratio411
    ratio411 Member
    Pensacola
    I am just playing 'devil's advocate' here...
    What about the 71-73 Mach 1 hood?
    Those scoops are low profile, designed by NASA, (NACA back then) they are supposed to be super effecient in taking in cool air. The Grabber scoops, while not exactly the same, are very close in design.
    Just a thought.
    Dave
  10. mavman427
    SLOtown, CA
    Any location close to the surface of the hood is not very effective. The one exception is the high pressure area on the base of the windshield, which is where the inlets are located on cowl induction. Cowl induction is much more effective than any scoops on the surface of the hood. The optimum place for air intake would be the stagnation point on the front of the car as I said in my other post. The moral of the story is that any scoops more or less level with the surface of the hood are stricly for looks and provide hardly an increase in performance at all. Additionally, the scoops on the grabber hood are so small that you wouldn't realize much performance gain even if they were in an optimal place.
    To picture what I'm talking about, think of a river. Right by the shore, the water isn't moving very fast. The water is hitting the shore, rocks, weeds, etc. and all of that is slowing it down. As you get out towards the center of the river where there are fewer obstructions, the water starts moving faster and faster. Basically, think of the surface of the hood as pretty much the water right next to the shore on a river. Air flow in that region is pretty much minimal from all the friction as the air moves over the hood.
  11. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    A cruel moment in life for me was when I was 17. Took the scoops out of my 72 grabber and expected noticable performance gain:( :cry: I was really bummed.
    Dan
  12. mavgrabber01
    mavgrabber01 Member
    Washington
    1972 grabber
    arent the grabber hood's scopes removable because mine are
  13. Dan Starnes
    West Central IL
    Yes, they are all that way.
    Dan
  14. mavgrabber01
    mavgrabber01 Member
    Washington
    1972 grabber
    that is what i thought so why would you need to drill out the scopes
  15. Mavaholic
    Because there will be 2 big ugly holes. The removable part has all the design in it.
