i-6 to v-6 swap
Discussion in 'Parts Interchange' started by carnzy's 70 mav, Apr 9, 2006.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You may get better mileage on a 302 with a small 4v carb.
    The stock unit is around 350 cfm, so if you use a 390 cfm Holley 4v, then you are only using 180 cfm on the front venturis. The carb is a vacuum secondary, so the rear venturis will only operate when needed. You could even adjust them further to come in a little late.
    Dave
  2. Jamie Miles
    Alto, GA
    I've had a few
    My 250 gets 25 at 70 mph after I put new plugs in.
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    ratio has a good point, when i went to 4v initially had a 450 cfm with vac sec. actually did see an increase in traffic mileage. went down when the road was open though, darn size 12s :whistle::D
  4. Cabinator
    Cabinator Member
    So Cal
    74 Grabber, 70 Maverick
    I have a 450 vacuum secondary holley laying around, i'll throw it on one of these days
  5. ratio411
    ratio411 Member
    Pensacola
    Isn't that all of our problems...
    We gripe about fuel cost and getting mileage, yet we still cannot control our need for speed. It's our cross to bear. :slap:
  6. carnzy's 70 mav
    carnzy's 70 mav Member
    Lincoln California:north of Sacramento
    1970 maverick with a 170 six cylinder and 3 speed transmission-floor shifter
    well folks after all the wonderful imput here i have decided to stay with the i-6 if i can't find one cheap enough and in good shape,i'll have to stick to my original and rebuild it...:tiphat:
  7. tim keck
    sharps chapel,Tn
    When I got over 20 mpg,it had headers & dual exhaust,a recurved point dist. and everything else was stock,even the old 2bbl carb.
  8. shortyforty
    shortyforty New Member
    NH
    First time here. I have a 63 Falcon and was thinking the same idea. I posted the question on the Falcon sight and the feedback was that the 3.8L is a tight fit because it is wider than the 289/302. My wife's 96 T-Bird gets 29 MPG city/hwy and 35 MPG on long highway trips (60-65 mph) with it's 3.8L and AOD trans. It seemed it would be a great combo in the Falcon.
  9. hot roddin
    hot roddin Member
    portland oregon
    1970 with a 250
    so... you guys are sayin that I should stick with the 250 I got in mine? it is all stock..
  10. maverick75
    have you considered putting in a Q-jet 2 barrel someone on here was putting one in their I-6, i'm not sure who but i think it was Hawkco
