I got a ford c4. I have an idea tell me if this can work.
Discussion in 'General Maverick/Comet' started by classic ccg, Oct 7, 2014.
  1. classic ccg
    ringgold GA
    72 maverick
    So I picked up a c4 to get my maverick back on the road. I had a b&m shifter that i can use so I'm trying to use some of the old shift linkage from the 3 speed on the tree. I have some pics but I will post more as I go.
    Also I was told it was a c4 but can it me a c5?
      File size:
      199.1 KB
      File size:
      220.8 KB
      43
      File size:
      210.6 KB
      42
  2. Krazy Comet
    RF-E2TP should be a C5, too new to be C4...
    You planning on making a couple miter cuts to fit that shifter???
  3. classic ccg
    ringgold GA
    72 maverick
    I hope it works that way. the seat may be in the way but now I need to know will a c4 drive shaft yoke fit the c5? and dose it have aod?
  4. Krazy Comet
    AFAIK yokes are same...
    C5 has lockup converter that will reduce cruse RPMs by approx 200, no overdrive...
    What engine are you gonna use this behind??
  5. classic ccg
    ringgold GA
    72 maverick
    Its a 80s 302 that came out of a f150
  6. Paul Masson
    1971 Grabber
    I used a C5 in my 4dr 15 years ago. That was behind the 200. I swapped the 200 bell housing and the torque converter (and maybe the shift linkage, too IIRC). Used the same yoke and driveshaft, never had a problem...
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    That trans is actually a C4s, they were used in med to large cars and trucks..... I should work in the mavericks with no problems, I ran one in my old Maverick in the 90's.....
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Isn't a C-5 just a beefed up C-4? I knew a guy who had one in mid-'70s a F-150.
  9. classic ccg
    ringgold GA
    72 maverick
    Thank you all for your help and info and i have a yoke on the way i almost have her on the road
