I got her home !!
Discussion in 'General Maverick/Comet' started by ChiefRocka, Feb 1, 2014.
  1. ChiefRocka
    ChiefRocka Father/Son 69.5 Build
    Hollister, Ca
    69.5 Maverick
    Thanks ....
    Lucky me , huh ?
  2. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    So I got up early, and headed to the shop this morning. I couldn't sleep in (never do, anyway) Just had to get this thing running right.
    As I mentioned before, I knew the carb had major issues ... I decided to start there. Pulled it off, and apart for a soaking in the Berrymans ...
    When I pulled off the Dist vacuum, I got spray with fuel ....
    More "Ghetto-Fab" work .....
    Float tabs were almost 'crimped' around mounts ... no droop ... :hmmm:
    After a few minutes in Blast Caninet, the cap and plugs are new again. The plugs 'were' new to begin with, just sooty ...
    Again, the Batt to Solenoid cable might be a little short ...
  3. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    I removed the points, and the plate.
    The bottom of the dizzy was nice and clean, lubed up the weights.
    I ran a compression test, and was pleased it was at least even across the board ....
    One screw had to be drilled out ... rusty and snapped off ....
  4. Dave B
    I love that cable...:rofl2:
  5. Krazy Comet
    You ain't ever seen a red neck starter delay???
    I bet the guy once ran a still...
  6. Dave B
    Or the 2ft one was the same price as the 8" one, more is better! (y)
  7. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Well, In between customer builds, I was able to get back on the Carter ...
    Man that thing way off ... Running a little rich was an understatement !!
    The seller told me "I don't think my buddy did a good job"
    :biglaugh:
    Here are some of the highlights ... how's this for float adjustments ??
    Wonder why this thing had so many manifold vacuum ports ... one in spacer plate, and three other at this junction. I know the vacuum valve on the t-stat housing used two in and one to dizzy, but still. :hmmm: Regardless, I removed the vac manifold and replaced with a pipe plug.
    Soaking in ChemDip, water blast, then to blast cabinet ...
    I had to make a gasket for the stud plate .... used sockets are "hole punchers" .... Then a rotary sander to open up center hole to mark.
  8. mav1970
    Suggestion to soak the parts again after blasting - those pulverized glass beads get right into the rough surface of cast parts and then come out when you don't want them to :)
  9. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Every port was blown with air, then blasted with cleaner, then air again .... numerous times.
    Its clean .... FOR SURE !
    Although I cant rope them all, this isnt my first rodeo ....
    (y)
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Those pictures are HUGE.
  11. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Thought everyone on forums liked pictures ?
  12. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    Hey guys, it's been a while since an update (well, that is because there isn't one :hmmm:)
    After building the carb, it just sat at my shop taking up space, so I brought it home, and parked it in the garage.
    My buddy gave me some skinny ww tires to use as temporay vintage look tires. Now, Looking for some tiny caps for it now ....
    The previous owner had installed some Monroe, overload-spring shocks in the rear ... and now I know why.
  13. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    After mess'n around with 3" blocks and removing the shocks, it came down like 5" !! :biglaugh::biglaugh::biglaugh:
    My intentions are to raise the rear back up 2", then have the front tire tucked like the rear is now .... So top of tread level with top of opening in rear, and WW about an 1" under front opening
    I cant here "War" playing in the background ... :)
  14. ChiefRocka
    Hollister, Ca
    69.5 Maverick
    This is all temporary ...
    The suspension will be all addressed at the same time as the V8 conversion
