I hate power steering
Discussion in 'Technical' started by demo913, Jun 7, 2011.
  1. 55crownvic
    55crownvic Member
    colorado springs
    just put a rack in it !!!!!!:thumbs2:
  2. maverick75
    Were still waiting on your "how to" :D If you ever have time to write one!
  3. 55crownvic
    55crownvic Member
    colorado springs
    Sorry for the wait, been real busy with car show season, not to mention my dad passed away a week ago. That alone is very time consuming. Will try and get the "how to" to you all soon, I do have to say that it was well worth doing, for me anyway. Its so nice to have the wheels turn at the same time the steering wheel is turned!! I can now look around at people lookin at my car, rather than having my eyes glued to the road. Ha!!
  4. maverick75
    Sorry to hear about your father :(
  5. timers
    timers Member
    richardson tx
    1974 maverick
    The auto krakters adapter has worked good for me. The alignment man said thanks for taking the factory slop out.
  6. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    So I started my conversion today. Many many problems. I noticed that the pitman arm for power and manual both have the same part numbers. Can I use the power steering one. The reasin I ask is because I have to grind my power sttering pitman arm to clear my exaust along time ago and dont wanna have to do that again. They look the same to me. I also can not get my power steering box out. What will I lose or gain with using the power steering box. Thanks...
  7. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    The manual pitman arm is straight and the power stirring is at an angle and also I think the whole on the arm is smaller. Don't sure on that part. The gear box is bolted to the frame there should be 3 bolts and you need to unbolt on the steering shaft that will let you remove the box. Call me if you have any other question 360-308-0422.
  8. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    i hate mine too!!!! so how much play is ''normal'' in the ball assm on p.s
  9. 71gold
    too much...i have never had one that was "tight", something to do with the...wiggly valve...that operates it...:drive:
  10. injectedmav
    injectedmav Member
    Georgia
    Yep, mine's loose too. If you constantly keep it greased it helps but it's a crappy design out of the box. I rebuilt the valve and it's not near as bad as some I have driven, but it's no rack and pinion or power box.
  11. 71gold
    got this from Jeffs web site...
    http://1bad6t.com/Maverick/repair/steering_02.html
    Power Steering
    POWER STEERING SYSTEM ADJUSTMENTS
    Control Valve Centering Spring Adjustment
    1. Raise the car and install safety stands.
    Remove the spring cap attaching screws and the spring cap.
    CAUTION: Be very careful not to position the hoist adaptors of two-post hoists under the suspension and/or steering components. Place the hoist adaptors under the front suspension lower arms.
    2. Tighten the adjusting nut snugly (about 90-100 in. lbs.); then loosen the nut 1/4 turn (90°). Do not tighten the adjusting nut too
    tightly.
    3. Place the spring cap on the valve housing. Lubricate and install the attaching screws and washers. Tighten the screws to 72-100 in. lbs.
    4. Lower the car and start the engine. Check the steering effort using a spring scale attached to the steering wheel rim for a torque of more than 12 lbs.​
    [​IMG]​
  12. 71gold
    pet peve...(about 90-100 in. lbs.)...isn't...90-100... already an about number...:slap:
    and...Check the steering effort using a spring scale attached to the steering wheel rim for a torque of more than 12 lbs.... are these...in. lbs. or ft. lbs?
    would 50 lbs. be a correct torque (more than 12)?:huh:
    wouldn't...no more than 12lbs. ...be what you're looking for?
    the torque setting on the screws that hold the cap on are as much as th setting for the steering...Tighten the screws to 72-100 in. lbs.:huh:
    ...I hate power (assist) steering...TOO
  13. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    Where do you get a manual idler arm. Every place I got to says manual and power use the same one. How do I know what year my center link is from. Does this matter when getting the idler arm or do I get it for the year of my car.
  14. rthomas771
    Master parts catalog shows the Idler is the same on both manual and power steering. The Pitman arm is different. 70-74 and 75-77 Idler Arm have different part numbers.
  15. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    If the idler arm is the same how do you attach it to a manual center link?
