I just want a fun car...
Discussion in 'General Maverick/Comet' started by 13Maverick, Feb 19, 2014.
  1. 13Maverick
    13Maverick Member
    Ohio
    '70 Maverick, '63 1/2 Galaxie 500/XL,'94 Chevrolet 1-ton dually,'86 Suzuki Samurai rock-crawler
    ...It's a funny thing about Fords, unless ya know someone who has or is a Ford-guru...the little things become so much bigger ! (lol) After my little jog around the storage unit-garage, I drove it to work and felt a vibration (like I was riding my ol'Harley)...then Ii remembered that the 5.0/302 is externally balanced, whereas the 3.8 isnt. Because I used the 3.8 flywheel and clutch, I could have spun a bearing if i drove it any longer or harder. So I drop the tranny again, switch the 3.8 flywheel for the 302 and go to bolt up the 3.8 clutch-set....no go! I precede to buy a '88 302 clutch-set and instal it...no go !...the bellhousing wont let the starter engage the flywheel! apparently the 3.8 flywheel and clutch-set are larger diameter than the 302. Phone call to Jeg's and I have an '88 bellhousing on it's way ! third time dropping the tranny and install the bellhousing. All back together and the clutch wont disengage...the pivot-ball is too short!...fourth time for the tranny-drop and the pivot ball installed and get this...the 3.8 imput shaft is 3/4 of an inch too long!...it bottoms out into the bearing in the crank. clutch depressed or not, the rear tires spin..."wonderfull"!...I order a 3/4" bellhousing/tranny spacer from Jeg's, a week goes by and I get an emil that the spacer is no longer produced or avaliable and I got my money credited.so i now have the correct length input shaft...funny thing about Fords...
    (the pic is the one day i did drive it on a sunny day...so the weather-man said ! notice the plastic bag on the velocity stack...lol )
  2. bartikus
    bartikus Member
    salt lake city, ut
    you could have just got a 351w flywheel out of a truck and it would have been the 164 tooth flywheel that would have matched the bell. you had purchased yourself a 157 tooth flywheel for the 302.
    13Maverick likes this.
  3. Krazy Comet
    Dismal Swamp
    Nope all 351 are 28 oz balance while the 5.0 beginning in '81 are 50oz, would have still vibrated... That said there should be 164T truck flywheels available for 5.0...
  4. bartikus
    bartikus Member
    salt lake city, ut
    I guess I should have read the beging of this thread again. I didn't realize he had a late model 5.0. Yeah that deffinatly would not have worked. I'm not sure about the 5.0 in trucks and what flywheel they used.
  5. Hotrock
    Munroe Falls, Ohio
    Welcome to the forum from northeast Ohio!!! :chirp:
  6. 13Maverick
    13Maverick Member
    Ohio
    Thankx for the replies...it's all a learning curve, so I'm still good with it ! Everyone keeps tellin me to stick with Chevies, but I'm not brand-specific, I think if ya love cars, every manufacturer has had their winners and loosers. I just happen to have fallen into good deals with the Fords.
  7. 13Maverick
    13Maverick Member
    Ohio
    thank you !
  8. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    Anyone can and does have a chevy wherever you go...but at the shows you will be the only maverick there!
  9. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    And guess which car will draw the crowd? Kinda like going to an Amish picnic wearing a mohawk and earings.
    Russell, NCFatBoy and 13Maverick like this.
  10. 13Maverick
    13Maverick Member
    Ohio
    Patients and persistence do prevail ! I picked up a brand new (in the box) aluminum radiator off craigslist for 100 bucks on Monday and some full-length chrome 302/maverick headers for 75 today. Hope they fit my GT40 heads, I'll be wrenching when the damn weather breaks! (hope to get some cruise time this year !)...laterz...
  11. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    Your "custom" power brake setup works with the strut tower brace?
  12. 13Maverick
    13Maverick Member
    Ohio
    yeah...but theres a catch, in order for me to use the brake/clutch pedal setup from the Mustang, I had to cut out the firewall and replace it with some sheet metal to move the "straight" brake pedal arm, to clear the steering shaft. I moved the holes over 3 1/2 inches and an inch lower. I do feel though, that the brake-booster would have still cleared the cross brace in the stock location. The second pic is the setup I had to engineer ...Maverick steering-shaft support,clutch/brake pedal assembly, booster. I did have to clearance (notch)the spring tower for the mustang master cylinder to clear. CAM00115.jpg CAM00114.jpg CAM00115.jpg CAM00114.jpg
  13. 13Maverick
    13Maverick Member
    Ohio
  14. groberts101
    groberts101 Member
    Minneapolis, MN
    Interesting and thanks much for sharing the learned info here. I missed this little tidbit before.. or maybe even more like "dismissed this mod" if I did actually read it. No offense intended.. pictures and action speaks much louder than words and all that.
    How does the system "feel" overall.. and how is the bias?
  15. 13Maverick
    13Maverick Member
    Ohio
    ...stops as well as any factory setup I ever drove did. I had a variable adjusted portioning valve on before, and couldnt get the feel right, so when i saw the factory 4-wheel disc brake portioning valve setup on the mustang, i figured it would do me just fine...and it does feel great. I havent measured or did a skid-test to see the actual results, but it stopped straight. I was just in shock when I saw that the Samurai-booster bolted right up to the pedal-assembly of the mustang...and then the Mustang master cylinder bolted right to it (without any modifications) i was kinda blown away!
