i lost a rod!!
Discussion in 'New Members Forum' started by ashtonN12345678, Nov 6, 2016.
  1. ashtonN12345678
    ashtonN12345678 Member
    eustace tx
    1976 ford maverick 4 door
    I can't get it out with the magnet. It's stuck good. Any thoughts
  2. 71gold
    turn the engine over, if it doesn't fall on through or nothing hits it leave it in there...JMO
  3. Acornridgeman
    Wisconsin
    Murphy's law at work.. I think if you can't get it out of there you will need to pull the engine and get the pan off to get it loose.
  4. ashtonN12345678
    eustace tx
    Leave it in there?
  5. ashtonN12345678
    eustace tx
    40-45 50-55 60-65 70-75 in counter clockwise spiral?
  6. ashtonN12345678
    eustace tx
    Do you happen to know the sequence for putting the rocker arm assembly back on?
  7. 71gold
    yep...
    Krazy Comet likes this.
  8. 70GreenMonster
    70GreenMonster Member
    Space Coast, Florida
    I don't remember the torque specs, but I do remember it was from the center out. We looked up the specs at the time in an old book.
  9. Krazy Comet
    Dismal Swamp
    Per the 1971 Ford shop manual, 30-35ft lb, tighten two turns at a time till the whole assembly has seated then torque... As far as order, just says tighten two turns at a time in sequence... As long as you don't go crazy(more than two turns at a time), order isn't important...
    ashtonN12345678 likes this.
  10. ashtonN12345678
    eustace tx
    I got it it's
    i got it it's 17-23
    17-23
  11. ashtonN12345678
    eustace tx
    Thank you
