I need help!!!!!!!!!!!!! Hope i came to the right place!!!!
Discussion in 'New Members Forum' started by 65 hardtop, Jan 6, 2012.
  1. 65 hardtop
    65 hardtop New Member
    california bay area
    1965 falcon hardtop
    datz y i bought a new 50 oz balancer
  2. 65 hardtop
    california bay area
    1965 falcon hardtop
    and i did hear the engine running befor installing it and it was great (y).... at idle its good but once u rev it to id say 2500 0r three it shakes and vibrates the whole car
  3. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    :Welcome: You came to the right place for answers.
  4. 71gold
    I'm thinking...wrong...balancer and flywheel...if the motor is a '73 302.
    Frank
  5. mav1970
    One of them or both of them wrong seems to be the consensus here :yup:
  6. Mavman72
    Ditto^^^... You need a 28oz balancer and fly wheel....Also, you will need clutch disc/pressure plate for the 28oz flywheel since the fox mustang stuff is metric and wont mount correctly to the 28oz flywheel.
  7. Joe Dirt
    you need a .028 oz balancer and flywheel
    keep running it with .050 oz stuff and you will be putting beaings and a new crank in it thats a good way to junk a motor
  8. bmcdaniel
    Yep, that's your problem. Small block Fords changed to 50 oz imbalance around 1981, earlier 302s were 28 oz imbalance. You can buy a 28 oz weight for the PP damper for about $15. Got mine at a local speed shop. CenterForce makes a diaphram clutch with a special release bearing that works on a old patterned flywheel. Or you can drill/tap new pressure plate mounting holes in the flywheel. I've done it both ways.
    What bellhousing are you using?
  9. 65 hardtop
    california bay area
    1965 falcon hardtop
    im using the bellhousing from the 90
  10. gmatthew76
    gmatthew76 Member
    Freeport, Fl
    1976 2 dr Maverick, 1977 2dr Maverick,1998 Ranger, 2004 Focus Wagon
    Sounds like maybe I was right Huh:huh:
  11. 71gold
    yep...he did leave out some important info...:Handshake
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    What about a late model flywheel off a 351 truck engine? Would it accept the Mustang clutch?
  13. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    I think the fly and belhousing are larger on trucks so it wouldn't match up.
