I need this intake!!!!
Discussion in 'General Maverick/Comet' started by RMiller, Feb 4, 2018.
  1. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    It was tempting for me and I’m 2 1/2 hours away!
    RMiller likes this.
  2. bmcdaniel
    RMiller likes this.
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Bet that's a bear to see around!
  4. CaptainComet
    I thought about the FI Tech style units, but the runner length made me lean toward injectors placed a lot closer to the heads.
    Thanks for posting the link. I have seen the FI Tech units used as a single four barrel replacement. Didn't know they also made matched pairs for dual quad setups. That may have potential on this manifold and tunnel rams, although probably work best on the regular low rise dual four manifolds.
    It would be cool to see what could be done with this manifold. It does seem like overkill, and sometimes that is just enough .... lol
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You really don't need a heat crossover on aluminum intake manifolds.
  6. stumanchu
    stumanchu Stuart
    Portland, OR
    I would suppose you dont, but I have read that if you block your heat riser, you should switch your boosters (Holley) to ones that create finer fuel droplets to allow it to vaporize in the absence of heat.....but I will admit that reading stuff is a substitute for inexperience more than experience.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Yeah, if you're driving in 10 below zero weather. 60 degrees and up it's a non-issue. My Edelbrock Performer RPM has no heat crossovers. A friend of mine blocked his crossovers off (Weiand Stealth) to combat a heat-soak problem and it runs great that way.
  8. baddad457
    You really don't want corrosive exhaust gases passing through that aluminum and the cancer it causes.
    Crazy Larry likes this.
  9. baddad457
    Old wives tales.....................I always block off the exhaust crossovers. And no negative affects from it.
