i NEED to know! asap
Discussion in 'General Maverick/Comet' started by MAVNWOT, Apr 21, 2005.
  1. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Ran when it was pulled but has been sitting for several years.
    I would personally rebuild it before using it, but then again I hate doing things more than once.
  2. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    1972 Ford Maverick, 302 w/ B&M tranny, everything else is stock
    was the 429 a Cobra Jet? i dont remember
  3. Jamie Miles
    Alto, GA
    I've had a few
    My grandpa has a 428 Cobra Jet Mustang, so I'm guessing a 429 isn't.
  4. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    cause i do know the 427 & 428 are both CJ's,,,but i didnt know if the 429 was also
  5. maverick1970
    Missouri
    They did produce a 429 Cobra Jet that was used in the Mustangs, Torinos and Cyclones etc. Cobra Jet was a name placed on the engine with the name came various changes like 4 bolt main blocks etc. The 427 never carried the Cobrajet name (didn't need too)
    http://www.musclecarclub.com/musclecars/general/musclecars-engines.shtml#ford-cobrajet
    The engine I have is a standard 429-4v that came out of a 73 Mercury Colony Park Station Wagon.
  6. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I have a 428 Cobra Jet engine in my garage that came from a 69 Cyclone CJ. I can tell you they are fast. But to try to put one in a Maverick or Comet would take a big hammer. They dont call them big blocks for nothing. I have been saving this engine to put in a mustang or maybe a 64 Fairlane to make Thunder Bolt clone.
  7. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    it is a 1973 429....i did find that out
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Hmmm....a 429 debate!
    Previous post is correct, 429 and 460 are the same engine
    family.
    The other previous post re: 'Cobra Jet' is correct, there was
    first a 428 CJ and then a 429 CJ.
    I have been around plenty of big blocks, plenty of them.
    I'd take the FE(Ford Edsel) motor over the 385 series anytime.
    The 385(429 & 460) seems to have a heavier rotating assembly.
    When built correctly, the FE (352,360,390,406,427,428) engines
    can put out a ton of torque and HP in a beautiful curve.
    The lower cid's posted are less performance minded and the
    427 is radically different. Edelbrock and some others make nice
    performing aluminum heads for these engines.
    I have seen some stealthy 460's, but it took a ton of work to
    get them to perform up to the standards of some of the
    427's that were slightly modified from factory specs. Keep
    in mind that the 427 was race minded as built. The 428 CJ
    used 427 style heads and was a torque monster.
    Good luck with your conversion.
    Seth
  9. Sam M.
    Sam M. Just a nobody
    Southern NJ
    I don't mean to sound harsh, but if you didn't already know that you couldn't use a C4 with a 429, then you don't know enough yet to make this swap. Like others have said, it's not just a drop in kind of thing. You need major suspension, drivetrain, and braking upgrades to pull it off. Sorry, I don't want to sound like a jerk, but you said you needed to know asap.
    Sam
  10. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    thanks...ill also keep that in mind
  11. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Yup, the 427/428 FE style engine only won Lemans two years in a row and powered some of the most legendary performance Fords all thoughout the 60s! Must be a real weak sister.
    Man, what an ignorant comment....sorry if that sounds harsh. :(
  12. maverick75
    i think they had 429 cj's and there are boss ones too.
    Have you though about Fuel Injection for your 460
    My uncle has one in his Lariot and man that thing haulls ass!
  13. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    the engine i am getting is a 429...and no i havent thought of that...but probly dont want 2, since its gonna cost like sh*t load of money...lol
  14. Jamie Miles
    Alto, GA
    I've had a few
    And YEARS to pull off if your on a budget. I see your the same age as me, I would think twice about this.
    A BOSS 429 is a whole diffrent monster, purpose built for NASCAR racing. Grandpa has one of those to...
  15. MAVNWOT
    MAVNWOT Member
    near Salina, Kansas
    im still getting this 429, since its for $600....just not going to fuel inject it or power adder for awhile
