I STILL have a drivetrain vibe and HOW do I get it fixed?
Discussion in 'Technical' started by scooper77515, Nov 29, 2009.
  1. scooper77515
    I will just get under the car this afternoon, drop the shaft and measure the caps.
    It is 1.125" +/- what? Is it supposed to be dead on?
    I would guess it would be, since they have to be pressed in on some applications.
    I sure hope this is the problem because that would sure make an easy and cheap fix. I am betting it is, because the guys that did the balance and put the new u-joints on had no idea what car it came off of, so they are probably the same size all around.
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    U-joints on my '72 need replacing. Anyone have a source that will supply the correct joints?
  3. rayzorsharp
    I hope it is too. Like I said, if it is, I can promise you the two caps held in by the u-bolts will be bad already. Needles will probably be destroyed as they can't last long when the cap is wobbling back and forth.
    Do you have a stock rear end of have you changed to a 9"?
    I think that's where my problem came from. My 9" takes a different cap size than the factory 8".
  4. scooper77515
    still running stock 8", and stock drive shaft.
    If I find a part number today, if I have to replace them, I will post it here.
  5. blugene
    And just cause it's tight doesn't mean it isn't under a load. Needs a good visual of it in hand.
  6. scooper77515
    GREAT CALL, Ray!!!
    :dance::dance::dance:
    Not sure if it will fix all the noise, but Ray was right. The caps were really sloppy in there, and only measured at 1.065".
    Off to O'Reilly to find the correct joint!
  7. scooper77515
    OK, part number for front joint is 280
    Rear joint was a 280 also, for the + and the 2 small 1.063" caps that go into the shaft, then I bought a 434 and borrowed 2 1.125" caps for the yoke, and it all fits perfectly. Now for a test drive.
  8. Jsarnold
    '72 Sprint
    Thanks, everyone, for the heads up and part numbers to make it work. I'd have been exchanging u-joints with many trips to the parts store.
    Am I reading you right, to replace both joints I should buy 2 280s and one 434 and swap caps? If that's right, I guess I'll have parts left over to make a spare front joint? Just noticed a new O'Reilly's store here. Guess I'll pay them a visit.
  9. rthomas771
    My 74 took part numbers 369 and 430. :hmmm:
    Best to take your old part anytime you buy a replacement
  10. scooper77515
    There are several part numbers that fit. Depends on the store, brand, etc. They were also looking at 255, and something in the 300s. But the ones I bought were the ones listed above, and they do in fact fit and work.
    Buy 2 280 joints, one 434, and take the 2 non-grooved caps off the 434 and put on one of the 280s.
    the 434 was just the first one I saw that had the 1.125" caps. The center + part is larger than the 280, so with my parts, you will end up with 3 caps and a + going into the trash. So if you can find another part number with the same overall length and the 1.125 caps, then you could end up with two complete sets for the rear after swapping caps.
  11. scooper77515
    Oh, test drive was not a success. I only got it to about 30 mph and now I have a NEW problem.
    Even though I did not hear the resonance during that short drive. So THAT problem may be fixed.
  12. Bryant
    sorry im late with this but check part # 353. we have it noted in a catalog here and its susposed to be the conversion u-joint for this.
  13. Jsarnold
    '72 Sprint
    Wow!! Here's what Oreilly's online catalog lists for 1972 Maverick 302. :rolleyes: Yes, I'll take my old parts with me. :tiphat: Again, thanks for the alert.
    Description Availability Price Master Pro U-Joint - U Joint - Premium
    Part Number: 369
    • Front Position
    • Standard Kit
    • 2 Year Limited Warranty
    Online:
    Available
    In Store:
    Available
    Add to Wish List Price
    $8.99 Each
    Part Number: 379
    • Front Position
    • Optional Kit
    • Flushed Zerk
    Online:
    Available
    In Store:
    Available
    $9.99 Each
    Part Number: 380
    • Front Position
    • Optional Kit
    • Zerk In Bearing Cap
    Online:
    Available
    In Store:
    Available
    $11.99 Each
    Precision Joints - U Joint - Non-Greaseable Super-Strength
    Part Number: 230
    • At Rear Axle
    Online:
    Not Sold Online
    In Store:
    Call Store For Details
    Add to Wish List
    Call for
    pricing &
    availability
    (919) 255-3490
    Precision Joints - U Joint - Greaseable Super-Strength
    Part Number: 255
    • Limited Lifetime Warranty
    Online:
    Available
    In Store:
    $18.99 Each
    Part Number: 269
    • At Transmission
    Online:
    Available
    In Store:
    Call Store Usually Available in 24 Hours
    Find store with item
    $15.99 Each
    Part Number: 280
    • At Transmission
    Online:
    Available
    In Store:
    Available
    $16.99 Each
    Precision Joints - U Joint - Premium
    Part Number: 369
    Online:
    Available
    In Store:
    Available
    $13.49 Each
    Part Number: 430
    Online:
    Available
    In Store:
    $15.99 Each
    Part Number: 430
    • Non-Stock
    • Rear Position
    Online:
    Not Sold Online
    In Store:
    Add to Wish List
    Call for
    pricing &
    availability
    (919) 255-3490
  14. blugene
    How do you get three caps trashed? :hmmm:
  15. blugene
    The links are no bueno.
