I STILL have a drivetrain vibe and HOW do I get it fixed?
Discussion in 'Technical' started by scooper77515, Nov 29, 2009.
  1. rayzorsharp
    Congrats! Glad it was that simple. Now get that engine fixed and go do some cruizin!!! (y)
  2. scooper77515
    Engine is already fixed. I just bolted the rocker back in, but I think I will pull them all out and lock-tite them in before I do anymore cruising. I had 3 loose intake rockers when I got into it today, one was completely "off it's rocker" and laying below the valve spring.
  3. yellow75
    Tillamook Oregon
    Scooper I cant believe that you didnt figure out it was a u joint, I would have said something about it earlier. When ever I get a vibration that is the 1st thing I check, its a pretty small part that takes a beating
    Remember K.I.S.S Keep it simple stupid
  4. scooper77515
    The ujoints were brand new. Less than a year old and less than 400 miles on them, so I had no reason to look at them.
  5. blugene
    Yea. We don't fly airplanes, but some things do need to be looked at reealll close. And with the u-joint, who would think it would have two different size cups.
  6. scooper77515
    From now on, I KNOW it has two different sized cups.
    But I drove on those other ones (I think two different sets) for 4 years. O'Reilly even lists them as the correct size, so I replaced them early on thinking they were correct.
    And all these years I had convinced myself that that airplane drone was normal for our cars.
  7. blugene
    Actualy our cars are very quiet like a Mercury ought to be... o yea, I forgot. Nevermind :p
  8. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Another option for the rear
    Got the new u-joints on the drive shaft. O'Reilly's had the 280 joint for the front. The specs for the 430 joint were correct for the rear but they didn't have it and couldn't get it. They found an alternative -- Spicer 5-1201X -- with matching specs. Got it the next day, and it fits fine.
    A tip for installing: put the joints in the freezer before you try to install them. That way you can put the pressed-in caps about half way in with your fingers before you have to put the squeeze on them.
    Again, thanks for the heads up. Ya'll saved me a bunch of frustration.
  9. blugene
    Are your rear cups two different sizes?
  10. Jsarnold
    '72 Sprint
  11. baddad457
    That's what a bench vise and 3/8 drive 11/16 sockets were made for. :thumbs2:
  12. rthomas771
    ...or axle grease, 1-1/16 socket and a sledge hammer. (I busted my 6" vise.)
  13. Jsarnold
    '72 Sprint
    Freeze 'em and the caps will slip part way in -- enough to start straight and for the X to hold the needle bearings in place -- and press in a lot easier. :thumbs2:
  14. blugene
    :hmmm: My + doesn't look like your X... :D
  15. rthomas771
    You're looking at it left handed. :tiphat:
