I think I need a new starter?
Discussion in 'Transmissions' started by Richard Kuss, Mar 25, 2015.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    Under fender
  2. Richard Kuss
    Red Bluff Ca
    Trunk drivers side
  3. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    I had that problem in the 80s, but my battery was under the hood. The heat caused the a plate in the battery to warp and short. Replaced the battery and was good. Obviously isn't your issue. Good Luck.
  4. Richard Kuss
    Red Bluff Ca
    My battery is reading 12.2, I turn on my headlights then turn key and headlights go off. Hmmmmm that buzzing is starting to annoy me
  5. Richard Kuss
    Red Bluff Ca
    My starter solenoid is reading 11.72 volts
  6. Krazy Comet
    Bad, discharged battery, iffy cables or excessive current draw... BUT if battery battery and cables are good you should be seeing smoke from the current draw... Measure voltage on batt post(not cable), if it's dropping more than a couple volts it's a battery problem...
  7. Mavman72
    Those grounds need to be clean metal to meal contact...Paint/rust are great insulators... That ground cable end in the trunk looks like crap...Cable looks dirty/corroded at that end too...
  8. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    That sound like a ground issue to me. You would be amazed how important it is the have a perfectly clean mating surface for the ground. Try moving the trunk ground maybe to the trunk latch bolts or a bolt through the the frame So it contacts both sides of the frame.
    PS nice looking Mav. I really want a EFI in mine too.
    Richard Kuss likes this.
  9. Richard Kuss
    Red Bluff Ca
    Thanks! Alot of hard work. Means a lot!
    I'll be busting out the wire brush tomorrow to tackle those grounds. I'll report back
  10. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Now for something completely different, where did you get that export brace/monte carlo bar setup?
  11. Richard Kuss
    Red Bluff Ca
    bought metal. measured, cut, bent, cut, welded, and sent off to chrome shop. lol
    jasonwthompson likes this.
  12. Richard Kuss
    Red Bluff Ca
    UPDATE
    Yesterday I took off my block ground and battery ground. Took the wire wheel to all contacts replaced an ate up battery terminal. Wire wheeled all the paint away at the two parts on body for good ground. Made everything nice and tight. Well the buzzing went away but still no turn over. Just rapid clicks. So I tested the battery. Sure enough it was 12.4 but once I started cranking it dropped down to 6.2ish. So I thought it could be my battery or Napa starter. I took my interstate battery out of the toyota. Tried that. Buzzing came back lol. After that the new starter solenoid got here from summit. Because I wanted to switch back to old style solenoid I originally had. Hooked it all up. Tried turning key again. This time the starter just spins and does not engage... idk anymore lol new starter maybe ?
  13. 71maverick361
    Odem
    71 Grabber
    Battery won't stand a load sounds like = bad battery
  14. Richard Kuss
    Red Bluff Ca
    But like I said I tried my interstate battery out of my toyota and nothing.
  15. 71maverick361
    Odem
    71 Grabber
    But did you try it after you cleaned everything?
