I think I need a new starter?
Discussion in 'Transmissions' started by Richard Kuss, Mar 25, 2015.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    Yes. The battery install was last.
  2. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Ok when you hook volt meter on battery and turn key to start position what's the meter show ?
  3. Richard Kuss
    Red Bluff Ca
    it drops from 12.4 to 6.2
  4. Richard Kuss
    Red Bluff Ca
    I didnt test it with the second battery cause it wouldnt start either so I kind of ruled that out. something is pulling alot
  5. 71maverick361
    Odem
    71 Grabber
    Could be bad starter ? Drawing a lot of voltage. Does it try to turn at all ?
  6. Richard Kuss
    Red Bluff Ca
    Doesn't try to turn over at all. First just clicked a bunch of time. Now the starter just spins and won't engage.. I think I'm gonna replace the starter
  7. 71maverick361
    Odem
    71 Grabber
    Try starter but make sure engine turns by hand
  8. Richard Kuss
    Red Bluff Ca
  9. 71maverick361
    Odem
    71 Grabber
    Dang that's a good price
  10. Richard Kuss
    Red Bluff Ca
    Yeah another guy on here sent me the link. I thought it was too good to be true. I called and spoke with the company. They're manufactured in the US by arrowhead electric. Said that starter is popular. They sell a few thousand a month and only 3% return rate. Plus 1yr warrenty. For that price I had to give it a try
  11. Krazy Comet
    Probably the same one I have on my Comet, so far has been great...
  12. mojo
    How long have you had it? The label on the starter say's "racing starter", how does it work in daily driver use?
  13. Krazy Comet
    Racing is probably nothing more than a advertising hype to make it more desirable... Kinda like Ford Racing HIGH FLOW 19Lb injectors... Those were in probably 90% of all engines built in '80s & '90s... A friend couldn't get past the fact they were HIGH FLOW, so had to be better than stock...
    Anyway so far starter has been flawless, been on there around year & half...
    Richard Kuss likes this.
  14. Richard Kuss
    Red Bluff Ca
    Got my new starter. Not sure if it'll work. Says will fit 91 Lincoln mark VII 5.0, which is the engine I have. Also my starter just has the one cable. The new one has like a coil on the side with extra wires. Any thoughts?
  15. Krazy Comet
    Wire it like second diagram, it'll be fine...
