I think I need a new starter?
Discussion in 'Transmissions' started by Richard Kuss, Mar 25, 2015.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    can I just run a small jumper wire from the big battery post to the mini starter solenoid?
  2. Krazy Comet
    Yeah, something on order of #12 wire will be plenty...
  3. Richard Kuss
    Red Bluff Ca
    So would the proper way would be to run a wires from the mini starter to the S on fender solenoid where my Red /Blue wire is connected to ?
  4. Krazy Comet
    WAIT!!! I messed up, no jumpers, wire it exactly as the diagram, use a #12 wire to activate the solenoid on starter(this is only addition)... Don't change any of the small wires on fender solenoid...
  5. Richard Kuss
    Red Bluff Ca
    got that lol
  6. Richard Kuss
    Red Bluff Ca
    So moved the starter big cable from right siDE to left of starter solenoid. And ran a wire from the right side solenoid down to the S on the mini starter solenoid. ? Correct?
  7. Krazy Comet
    yep sounds like you got it...
  8. Richard Kuss
    Red Bluff Ca
    starter just spins just like before sounds like grinding but flex plate is untouched. serp belt starts to spiin for a half a second and freely stops
  9. Krazy Comet
    If it's grinding you need to look at the flexplate, sounds like it has some chipped/broken teeth...
  10. Richard Kuss
    Red Bluff Ca
    It's not. I've already checked. It was making the same noise with the last starter. It's not cranking at 12v. It wants to turn over. Around 6 when cranking
  11. Krazy Comet
    How many teeth are on that starter drive??? The origs for 157T C4 flexplate had nine and a spare PMGR I have from Explorer has 10... No idea how many the one on my Comet has, was purchased as working with earlier engine & trans combos...
  12. Richard Kuss
    Red Bluff Ca
    164th flex plate. It's a pan fill C4
  13. Krazy Comet
    If the battery voltage is dropping to 6v(as measured on batt post, not terminal) and cables aren't smoking, you likely have a bad battery(yes I know it's new)... Have you pulled plugs to see if it'll spin freely without compression??
  14. Richard Kuss
    Red Bluff Ca
    No I havent. Sorry for the late response. I've been training the last few months (Army) and haven't had time to work on it. I'm looking to pick up right where we all left off. I'm hoping to get this tackled in the next week or two, or I'm going to have to send it home and have it worked on.
  15. Richard Kuss
    Red Bluff Ca
    I'll be posting tonight with more pictures and detailed description of where I left off to see where I stand.
