I6 Radiator for V8 302 swap
Discussion in 'General Maverick/Comet' started by Slk70, May 7, 2007.
  1. Slk70
    Slk70 Member
    Los Angeles
    PM Sent... thanks
  2. Campmaverick
    Campmaverick Member
    Reedley ca
    1972 Maverick grabber
    What Radiator hoses are you guys using with your six cylinder radiator bolting up to 302 the inlet on the radiator is very small can somebody point me in the right direction
  3. fredee
    fredee Member
    South MS.
    1971 comet
    Sounds like you have a 200 6 cyl radiator. The 250 would have had the same size inlet as a 302. I'm sure a radiator shop could put a bigger inlet on it but you really should go with at least a 3 core if your staying with a copper one. You can find an aftermarket aluminum 2 core that has larger cores.
    71gold likes this.
