I6 Tranny question.??
Discussion in 'Transmissions' started by anthonyv90, Oct 21, 2008.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    i was wondering what would be the best tranny i could put in a 200-ci 71 maverick..???:huh: because it takes a long time to switch from 1st gear to 2nd gear.
  2. 71gold
    is yours a 3 speed or automatic?
  3. anthonyv90
    anthonyv90 Member
    its an automatic transmission...column shifter...
  4. PaulS
    Your C4 can be made to shift a lot faster than it does from the factory. The TransGo 40-2 kit will do it for about $70 - $90 US if your C4 is in good shape.
    The C4 is not only the best automatic for your application it is probably the least expensive alternative.
  5. anthonyv90
    anthonyv90 Member
    Where can I get the TransGo 40-2 kit.?
  6. anthonyv90
    anthonyv90 Member
    I was wondering if I could put a E4OD tranny on my 200ci 71 mav.?
  7. don graham
  8. PaulS
    TransGo kits are available from most of the online performance stores or you can go to a specialty dealer like Broader Performance. The specialty dealers charge a bit more but at Broader Performance you get more because they provide you with a few extra tricks to juice up the kit and Jay provides the best customer service to his customers that I have ever seen. It is almost as good as my own. :)
    There are no overdrive automatic transmissions that will bolt up to the 170 and 200 cu" engines. The C4 is your only automatic alternative that will take any abuse.
    There are a number of standard transmissions that are OD equipped if you are willing to spend the money to change over to a manual.
