Identifying motor size
Discussion in 'Audio' started by Campmaverick, Apr 17, 2022.
  1. Campmaverick
    Campmaverick Member
    Reedley ca
    1972 Maverick grabber
    Identifying motor size Is there numbers on a six cylinder that tells you what size it is I have a 68 motor don’t know the size evidently I didn’t come in the car
  2. Craig Selvey
    Maybe somebody else will chime in, but the starter location and the number of water pump bolts will tell you the size.
  3. Campmaverick
    Campmaverick Member
    Reedley ca
    Well I know it’s not a 250 six cylinder never heard of counting the water pump bolts thanks
  4. Powerband
    Powerband Member
    NY's \H/
    I have a 68 motor don’t know the size evidently I didn’t come in the car:
    Ford small block six 170/200/250 can be ID'd:
    Important engine series numbers are behind high mount starter on 170's and 200's. IE - C8DE or D3DE etc...
    ALL later 200's have 5 freeze plugs under exhaust manifold - 170's have 3 freeze plugs.
    All 170's and 200's in '3pedal Mavericks' and late Mustangs use "Toploader" style Bellhouse - Automatics use older bellhouse - 'small pattern' for C4.
    ALL 250's have the starter below the engine block and use same FW, Clutch , Bellhouse as SBF V8.
    and as per Classic Inlines pages:
    Water Pumps: All 144/170/200ci engines used a 3 bolt water pump, while the 250ci six utilized a 4 bolt water pump. This is the easiest way to distinguish a 250ci from the 144/170/200ci six.
    have fun
    Craig Selvey likes this.
  5. Campmaverick
    Campmaverick Member
    Reedley ca
    Thanks a lot great info to have . Thanks
  6. Powerband
    Powerband Member
    NY's \H/
    Maverick 170 with three freeze plugs was the last of the original small block six design. the 200 and 250 have 7 main bearings, the 170 has 4 mains'. Not to be counted out though, the 4-main six is also last Ford used in 50's/60's Raceboat class that created six cylinder racing research and an Six - aftermarket speed equipment industry.
  7. Campmaverick
    Campmaverick Member
    Reedley ca
    Yeah mine must be a 200 it has the five freeze plugs and three bolt water pump
  8. Campmaverick
    Campmaverick Member
    Reedley ca
    It’s been bored 30 over so would that make it like a 207
  9. Campmaverick
    Campmaverick Member
    Reedley ca
    It has the one barrel Carter carburetor it’s a 68 motor I’m wondering the horsepower
