Idle Issues
Discussion in 'Technical' started by Bubba Bob, Jan 13, 2009.
  1. rthomas771
    Check the float level
  2. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Is that the screw on the left side of the Carb near the top?
  3. rthomas771
    Holley is externally adjusted at the top of the bowl at the fuel inlet . Edelbrock in internally adjusted by bending the tabs on the float. Both dry float and float drop needs to be adjusted
  4. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    ok, it is running better, but now it will not "Idle down" when I put it in park or sit a stop light, do i have it out of adjustment still? I fi manually release the accellerator cable it will idele down fine. Thoughts?
  5. Mavman72
    What kind of carb do you have??? Carter single barrel or a holly 2 barrel??? By manually releasing the cable do you mean pulling off the carb linkage or just pulling it to closed throttle position???
  6. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Sorry, it is a carter 1 barrel and I meant i am pulling the throttle to the closed position. I cleaned it really well and made a few adjustments and it seems to be working now. This car has not been running for 33 years so I am sure I will run into a few issues.
  7. Mavman72
    You may want to put a return spring on the linkage if its gone/weak...stuck throttles are not fun...especially in rush hour traffic.:yikes:
  8. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    thanks, i am going to check it out. . i drove it to work today it ia bout a 45 mile commute, car ran great but it will not idle down and it is sucking gas.
  9. Mavman72
    Is your choke working properly??? It will cause your high idle and poor fuel economy as well if its sticking shut.
  10. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    I guess that could be it, when I stop I have to go under the hood and manually disengage it to idle down. Is there a way for me to test it? Is it a seperate component that I can replace? or do I have to but the entire carburetor?
  11. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    What is "it" that your have to disengage?
  12. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Sorry, the throttle and it seems to stick more when it is at operating tempratures.
  13. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    If the choke stays shut, there's a doomaflatchie driven by a lever coming from the choke that keeps the idle up. Look on the drivers side of the carb and open and close the choke and push and pull the throttle linkage and you can see how the whole thing works.
    On the back of the carb is a little black doomaflatchie w/ three screws. Take those three screws off and take that black cover off *take note of how everything comes off, and dont drop anything*. The choke is controlled by a heat sensitive coil under that black housing. Once you get a good look at it, you shoud be able to see how it works. With that car cold, adjust it so that the choke is just barely shut all the way.
  14. kamadelaney
    kamadelaney Member
    Spring Hill, FL
    75 Ford Maverick
    Sounds like fun, and in a language i understand!! I will let you know how it turns out!! :oops:
  15. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Oh, and if that doesn't fix it, which I suspect it wont (but the choke sitll needs adjustment - no way its still correct after so many years), clean all the throttle linkages real well, and spray some lubricant around.
