If you had to choose
Discussion in 'Technical' started by ptpdub, May 5, 2018.
  1. ptpdub
    ptpdub Member
    canada Sk.
    Would you choose a chrome four blade mechanical fan or a Six Blade plastic Fan to cool a very mild 302 Neither fan will have a shroud
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    My first choice would be the Taurus electric fan upgrade, but if I had to choose between the 2 fans shown, I would use the metal one and toss the plastic one in the garbage.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Neither. A stock 6 blade fan is better.
    And definitely get a shroud.
  4. ptpdub
    ptpdub Member
    canada Sk.
    That’s what I thought. Why is the plastic one junk? I have never used one before so I am uneducated.
  5. Krazy Comet
    Watch & learn... BTW you should always use a shroud...
    Jaybee and ptpdub like this.
  6. mojo
    I don't believe either will keep the engine cool w/o a shroud. Warm/hot days, slow traffic, long train delays equal rising engine temps. A open fan is also dangerous; accidentely get a limb across a blade -- goodbye to that limb.
    Ronald Hopkins, 71gold and ptpdub like this.
  7. yellow75
    Tillamook Oregon
    If those are your only choices then stick with metal, I would be afraid to open hood with the plastic fan turning, but like others have said shroud is needed
  8. baddad457
    But keep in mind that the more blades it has, the more power it takes to rotate it. Electric is the way to go here in my opinion.
    Crazy Larry and Buck62 like this.
  9. Buck62
    Buck62 Member
    Chicago IL
    1974 Mercury Comet (Base)
    We went with a Spaal electric fan.
    No regrets here! :thumbs2:
  10. bmcdaniel
    I had one of those fiberglass fans fly apart on me many moons ago. Sliced right through the upper radiator hose. Then ran a six blade aftermarket metal fan that worked ok. Neither compares to the Taurus electric fan I picked up on Craigslist for $30.
    jasonwthompson likes this.
  11. dmboshkov
    dmboshkov Member
    Ambato - Ecuador
    76 Maverick
    Hello, please can you share the item number or cfm of that spal fan?
  12. Constable
    Constable You have the right to remain silent....or not!
    Portersville, PA
    1975 Maverick 4 door, 1994 Mustang GT convertible
    Using a shroud just makes sense. It channels the air to make cooling more efficient. I was concerned that the aluminum 3 row rad I bought for my Mav wouldn't allow me to reuse the original shroud but it did and pretty nicely at that. And A metal bladed fan always beats plastic. More rigid and moves air better. Electric is the way to go but if you want to stay original, go with a metal fan.
