If you like Comets
Discussion in 'General Maverick/Comet' started by blugene, Feb 1, 2008.
  1. Tlowery643
    Tlowery643 Member
    Rockmart, Georgia
    Thanks for posting Gene, I hadnt seen it and it is awesome!!!! You know how I love Comets!!!!!
  2. blugene
    I figured YOU would like that. :Handshake
  3. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Looks about right. A Comet tearing up the track and chirping brodies all over the place. Wicked fine car. Just incredible.
  4. blugene
    And of course I new you would like it as well... even tho it aint white.
  5. Mercurycruizers
    Venetia, PA
    I love a Comet that can make people go "Damn!" Makes me want to put a little more horsepower under the hood. Thanks for sharing....
  6. blugene
    Here's one I hope I can match up with :cool:
  7. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    1974 Comet Gt 351W T5 8.8 .520/.545 hydraulic cam 1 5/8 headers
    love both of 'em. the first car I've seen in person. it's awesome. all of the nighttime clips are at my local dragstrip, shadyside, in boiling springs, nc. Note the hard left turn at the end. Seen a few pro-mods and REALLY fast cars not quite make it. Seen a 86 or 87 camaro with a 434 or something cut down a few trees. Nitrous bottles exploding and everything. It was bad. Kinda glad they're redoing that place.:)
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Thanks Gene much appreciated.Found out that day that the valvesprings didn't like 7000 rpm.If you listen close you hear the valve float in the first burnout.:biglaugh::rofl2:
  9. blugene
    You have an awsome car Derek :thumbs2:
    Mine sounds like that from what I can remember. :( I never got the outcome your having but I also never got to finish anything I started due to life. I will be back on it real soon.
    What engine, trans, diff do you have? Gimme your specs :mischeif:
  10. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
  11. Derek 5oComet
    No problem Gene,Everything is plain simple stuff.Here goes
    1991 5.0 L H.O 100,000 miles
    cleaned up,new head gaskets and valve seals,oil pump.
    Ford racing B303 cam
    Crane Beehive springs
    Stock pushrods and rocker arms
    Edelbrock performer RPM Intake
    650 DP Holley
    Duraspark Dist
    Headman Headers 2.5 exhaust,2 chamber flows.
    Stock replacement clutch
    T-5 trans with about 60,000 miles
    3'' Driveshaft from Fox body Mustang
    9" rear from 68 mustang 3.89 gears and trac lock
    Traction bars found in auto wreckers cut and modified to work
    Well i guess thats it nothing special here,everything just.....kind of works.
  12. ryan's ride
    ryan's ride Member
    vancouver B.C. Canada
    1973 comet
    Hi guys, that is great. I loved the videos. I have seen Derek's car on youtube before. I love the sound. As for the other comet with the 347, it was great to see the wheel stands. I was looking for sparks off the rear bumper on the one wheelie! sweet ride. Derek, I ran a 91 5.0 in my first comet. I took off the serpetine belt drive and bolted up my '73 front end(waterpump, pulleys, power steering, and alternator.) then dropped on top the 1985 intake and carb. from the mustang. I put the stock exhuast manifolds and put them on the new motor. I thought that the headers wouldn't fit. I kept the C-4 and got a new smaller flywheel and had it balanced to 91 specs. Then I put a shift kit in the tranny. ( I was toasting it really quickly otherwise) Just never changed the rear end. The 8 inch held up fine, just no posi. After seeing these videos it just gets me going again. I really would love to modify my current comet. How did you do the swap of the T-5 how did it fit, and pedals and everthing? Did you make new cuts in the firewall for the clutch pedal? Did the driveshaft from the stang just bolt up? Did it have to be shortened or is it the same lengths as the stock comet drive shaft? Any more info like that would be great.
  13. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    The t5 fits good in my '74 gt. as far as switching the pedals, all hangers should be the same. slide out your brake pedal and slide in the new clutch and brake pedal. you should have a fact. hole in your firewall you can knock-out or you can drill one for your clutch linkage, or you can make a cable set-up work. my driveshaft is a stock mustang one and it fits fine. there are several lengths to these though depending on which car you get it from. i use a t5 bellhousing but converted over to the old style mechanical linkage and fork. My comet is a blast to drive with the t5 and I would recommend the swap to anyone.:thumbs2:
  14. Mavaholic
    Wow!!! I have seen Stephen's car in action. I knew he was redoing it but.....WOW!!!!! Is this thing still going to be street-able?
  15. Dave B
    Heres a picture of the Comet I had. It was a little rusty..
