Ignition conversion??
Discussion in 'Technical' started by gyrojunkie, May 20, 2012.
  1. gyrojunkie
    gyrojunkie New Member
    Astoria
    72 maverick
    Has anyone converted their 250 to electronic ignition? and what conversion kit is the best?
  2. cody674
    cody674 Member
    1972 Ford Maverick
  3. gyrojunkie
    Astoria
    72 maverick
    Thank you ... I will look into it.
  4. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I would do the Petronix upgrade. I got a ignitor II and flamethrower II combo on e-Bay for about $120 free shipping.
  5. Dave B
    Hot Spark looks like a knock off of Pertronix, I've never seen them before.
  6. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I agree. I looked at both in person before deciding. hot spark feels cheap and looks cheap.
  7. rthomas771
    I'm running a $20 Duraspark II that I got from the junkyard.
  8. maverick75
    Durapark is the best one in my opinion, Like Jeff I got all the stuff from a junkyard for $10.
    And if something breaks down you can pick up a replacement part at any parts store, vs having to order one online and waiting days to receive it. Or hoping one of the parts stores has a 6cyl conversion kit in stock, which is almost never.
  9. Dave B
    Who's ever had a Pertronix fail? :huh:
  10. maverick75
    I don't know! they came out before I was even born. But I've never had a duraspark fail either in the 4 cars that I've run it in.
    Heck D.S. was so good MSD ripped it off :D
    If you google "petronix problems" it does happen quite often, but then again so does any other system that isn't maintained. The blame is often on the product when it should be on the owner.
  11. Dave B
    I've had way more Duraspark boxes fail :D
  12. cody674
    cody674 Member
    1972 Ford Maverick
    hot spark is a cheaper one iv run it for about 6 mouths no problems and its only about half the price its about 60 dollars
  13. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Too bad you spent 60 bucks on that. for 25 more you could have had a petronix Ignotor I and Flamethrower I with wires. New from reputable dealers on ebay all day every day. But heck if you are ok with cheaper build quality it's your money and your car.
  14. cody674
    cody674 Member
    1972 Ford Maverick
    its not build that cheap im telling ur it works pretty good
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Well I can't claim to have done more than handle one for a few minutes at a car show last year. But my experience tells me it feels cheaply made. The one I was examining had moulding issues that imo could potentially lead to failure of the device from contamination entering the housings. But, then I spent 2 years deciding on what I was doing for ignition upgrade.
    After spending a lot of time looking up electrical references between parts and my engineering handbook for automotive applications I decided on Ignitor II, Flamethrower II, Ford Racing 9mm wires (I used the HEI distributor cap Scooper - I think - suggests if you search the forum here), and a .042 gap on my plugs.
    The electrical Specs on the Hot Spark units are a bit inferior and from the pure electrical aspect wouldn't work in that configuration. I'm particularly leery of their coils but I haven't had the opportunity to even see one in person for build quality.
    Edit- I'm getting about 16 miles per gallon during my daily drive that involves this ( http://maps.google.com/maps?hl=en&s...code_result&ct=title&resnum=2&ved=0CA0Q8gEwAQ ) 5 mile drive over the Portland west hills every day. For comparison my 5.0 efi, manual 5 speed Bronco averages 10mpg on the same road, and it can't climb over the hill at 50-60 like the comet can. The map doesn't show it but according to a bicycling site the average grade is 6.5% and the max grade is 10.78%.
