Ignition key lock issue
Discussion in 'General Maverick/Comet' started by 50forder, Apr 11, 2024.
  1. 50forder
    50forder Member
    California
    1973 Maverick
    I have a 1973 Maverick that was produced (according to the door sticker) in 2/73. I purchased the lock cylinder appropriate for my car, which looks identical to the old one I removed. my issue is that when I put the lock cylinder in run position to depress the pin for installation, the end of the cylinder (triangle shape) does not match up with the corresponding notch in the column?
    has anyone had this issue? Can the notch in the column be rotated to match the lock cylinder?
    Thank you for any advice you can give.
  2. krelboyne
    krelboyne Remember
    Salem, Oregon
    Doesn't match up, or is a different shaped notch?
  3. Krazy Comet
    You likely have incorrect lock. Per Ford Master Parts, lock changed 5/14/73
    Part number before 5/14 is D2AZ-11582B(quick replace SW1114).
    From 5/14 number is D4AZ-11582A(quick replace SW1191)
  4. Krazy Comet
  5. 50forder
    50forder Member
    California
    1973 Maverick
    Same shape, just seems to be turned different directions. Here is a picture of inside the column and one of the key lock in the run position.
  6. 50forder
    50forder Member
    California
    1973 Maverick
    I believe I got the correct lock. The car was built in Feb of 73 and I got the early style lock. Not sure what I’m doing wrong. Ugh!
  7. Krazy Comet
    Tomorrow, I'll look at a '71 column I have, should be same as your '73.
  8. Krazy Comet
    Looks as if your switch is in wrong position.
    Move small end to two o'clock position.
    dyent likes this.
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I thought you needed to be in the accessory position to depress the tab. It's been a very long time since I took one apart so those memories could be miles from the truth though.
  10. Krazy Comet
    In dash locks install using ACC position, column locks install in RUN position.
  11. RMiller
    Kennewick, WA
    See, that's what happens when I think!
  12. Krazy Comet
    LoL, if I said I didn't double check before posting your reply, I'd be lying. Made me think.
    RMiller likes this.
  13. 50forder
    50forder Member
    California
    1973 Maverick
    Thank you for the picture. I had to actually use a screwdriver to turn the notch in the column so it would line up correctly with the notch on the key lock when in run position.
    Krazy Comet likes this.
  14. Krazy Comet
    I've had several over the years that screwdriver was the key. :thumbs2:
    Taking pict was hard part, I couldn't get inside car so holding light and phone from left was challenging. Steering wheel already loose, key in the ignition, that was easy peasy.
