Ignition lock cylinder
Discussion in 'Technical' started by Hairy W Bush, Nov 9, 2014.
  1. scs
    scs Member
    Prescott wisconsin
    1972 Maverick Grabber
    Long shot here, but make sure the column shifter is in park (I'm sure you tried that, but....). I struggled for days until I rotated the column to Park (if not Park, try others). Even if you have a floor shifter, it matters where the column shifter shaft is rotated.
  2. Hairy W Bush
    Hairy W Bush Member
    Georgia
    yup it's a manual so I'm supposed to put it in reverse which it is in.
  3. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    These cars were suppose to be easy. Your having issues I never had with my three. I am going back an check service manuals on that one. When I get home. I forgot to take a picture of the column. Need to start making notes to myself. Talk later Hairy. Sorry for all the problems your having.
  4. schroensr
    1975 Mercury Comet
    Was that car always a manual or automatic changed over.
  5. Craig Selvey
    I see you say the car is a manual and it is in reverse. You might also try wiggling/rotating the column "collar" directly below the "collar" with the ignition switch in it.
  6. rthomas771
    Here is a switch that was used between 71-5/15/73 on left and the switch used between 5/15/73 – 1/76 switch on the right. Notice the thickness of the pin and width of the tongue. I don't have a switch used between 2/76-77 to compare what could be different.
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    oh damn guess what this new one does not look like that. but according to schroensr's book it's right. the pin is small but the end of the shaft does not have that space in the middle. but it's like that for both of my cylinders and every new one i look at (rockauto) is the same way.
  8. schroensr
    1975 Mercury Comet
    If you need one with keys. I can send you a 1974 comet one no charge.
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    that won't work unfortunately because the later ones appear to have a wider ridge where the pin sits and my column HAS to be the correct column because it's the right size for the cylinders i have now.
    I rotated that collar you guys suggested and it doesn't even move the slot at all.
