ignition problem
Discussion in 'Technical' started by Kenfleishman, Dec 31, 2012.
  1. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Its on the column under the dash. You will probably need to drop the column to change it.
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Check your neutral safety switch.
    I had one that worked intermittently. Several times I spent hours digging around the dash trying to figure it out. I must have bumped the switch because suddenly it would work again. It drove me nuts. I couldn’t figure it out. Finally, I bypassed the switch and never had a problem again.
  3. x72COMETx
    x72COMETx Member
    Vallejo CA
    i already bypassed the nuetral saftey switch it never work
  4. rthomas771
