Ignition switch part?!
Discussion in 'Technical' started by hbmmusic, Mar 1, 2012.
  1. Acornridgeman
    Wisconsin
    Battery with a dead cell - yes, I agree, a strong possibility. Easy to do a load test / cell check at any auto store.
    I have had headaches before with the directional switch. It is like the brain box of the wiring sometimes. Many problems can be traced back to a bad directional control switch.
  2. simple man
    simple man Member
    Bunnell,Florida
    If you are taking your voltage readings directly from the battery, it's definitely not your switch! Bad battery or charging system issue, as others suggested. :)
