Ignition Switch
Discussion in 'Technical' started by MuscleMaverick, Nov 22, 2009.
  1. MuscleMaverick
    MuscleMaverick Member
    Issaquah Wa
    1974 Maverick 4 door
    also how do i go about removing the shrouding from the column?
  2. 71gold
    there are two studs w/nuts. loosen the nuts and slide the switch up/down to adjust...turn the key into the start position and hold it there as you move the switchm up/down.:yup:
  3. MuscleMaverick
    Issaquah Wa
    Thanks for the help i just need to go and grab it quick then come home and put it in. After about 3 hours of trying to take it out :)...
  4. MuscleMaverick
    Issaquah Wa
    got the switch and i put it in would it be having problems running and idling if the switch isn't right?
  5. rthomas771
    The switch is either off or on. Sounds like another issue.
  6. MuscleMaverick
    Issaquah Wa
    it was running fine before i put in the new switch (with hot wiring it) would you have any ideas? wire maybe get unplugged? I have messed around with the carb with no luck it is smoking a little out of the carb (i figured just extra gas)
  7. NorCalMaverick
    NorCalMaverick Member
    Pinole, Ca
    1974 Ford Maverick 2 Door
    my '74 2 door needs an ignition switch but not sure which part is bad. I have a digital multimeter would I be able to check with that? the guy I bought it from had to jump it at the starter solenoid since turning the key did nothing. any advice?
  8. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    switch
    After Checking all That Stuff You Might Want to Try A Ignition Condensor. The Little Can Mounted on the Distributor. It Will Affect the Idle and running. the Distributor Points Get Reduced Voltage Through The Factory Wiring about 6 Volts and You Said it Ran OK with Full Battery Voltage 12+........Just a thought.
    Cris73 likes this.
  9. Krazy Comet
    Dismal Swamp
    Neutral/Park safety switch... Will it crank in neutral??
  10. NorCalMaverick
    Pinole, Ca
    no wouldn't do anything in neutral but after reading though this forum and talking to a couple guys on facebook ive found out its the wired pigtail in the column and not the tumbler.
  11. Octavio
    Octavio Member
    Chihuahua, Mexico
    1977 4 door automatic
    Hi! my 1977 ford maverick failed to retire the key, after some complicated maneuvers and some travel to the parts store, we realized that a piece that links the key and the switch is missing and the switch is also a little bit worn, a new switch may be used? where to buy it? thanks in advance.
  12. Krazy Comet
    Dismal Swamp
  13. 302yellow72
    302yellow72 Member
    Poulsbo WA
    1972 Maverick 302
    I just did my ignition switch last week. I picked it up from NAPA for about $40. Was happy that all the wire colors matched the factory.
  14. maverick600
    maverick600 Member
    San Angelo, Texas
    I know this is an old post but were there differences in switches over the years? I have a 70 but will any of them work or are they year specific?
  15. Craig Selvey
    You need a 1970 switch
