I'm back & cluster issues
Discussion in 'General Maverick/Comet' started by Ryan Whiteside, Mar 13, 2015.
  1. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Howdy folks. Been absent a few months. Between the holidays, working 16 hour days 7 days a week, and family it's been hard to get on. Finally back to normal shifts. Hope everybody is doing OK and look forward to getting back in the mix.
    Now onto the cluster issue. Had to replace the speedometer cable. After reinstalling everything and cranking the car for the first time the cluster apparently grounded out. Everything mechanical wise still works. The back lights for it no longer work unless the high beams are on. Any suggestions as to what may be causing this issue or is a new cluster needed. I have checked all fuses and relays and they seem to be in working order. Any help is greatly appreciated.
  2. Moneymaker 1
    Panama City Florida
    headlight switch may be bad.
  3. Earl Branham
    Lugoff, SC
    Ryan, check the connector on the back of the cluster, not for a bad connector, but for a bent contact on the circuit board on the cluster. Those things are real boogers to stay down and go in straight. I put a dab of super glue under the contact fingers to hold them down. Worth a check.
    Krazy Comet likes this.
  4. Krazy Comet
    Dismal Swamp
    Agreed, the finger for dash lights is probably resting on high beam finger...
  5. Ryan Whiteside
    Appreciate it. That was the problem
