I'm considering getting a manual tranny . . .
Discussion in 'Transmissions' started by mashori, Nov 20, 2009.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    i think the hydraulic clutch is easier to install and not as hard of a pedtal and no burning the clutch cable on the exhaust
    i used the cnc ones
  2. 302-72-mav
    302-72-mav Member
    sactown CA
  3. 302-72-mav
    302-72-mav Member
    sactown CA
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    a regular t5 is gonna have some trouble behind a blown 331 with nitrous
  5. 302-72-mav
    302-72-mav Member
    sactown CA
    my world class t-5 holds up to 300 foot pound's of torque
    i think the non world class ones hold 280 ?
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    thanks for the PM, very helpful, I'm gonna post it here if that's cool with you.
    Also, how did you figure out the clutch linkage, I need to still decide on the the hydrolic vs cable.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    correction. . . ethanol, not nitrous! I know, I keep changing my mind but think I'm sticking with this combo this time . . . unless I change my mind. :drive:
  8. Bryant
    mo's car is going to be a street car. he may make it to the track but i dont think that he will be on slicks. ive advised him to use a stock replacement clutch so it wont be able to shock load the trans enough to brake it. that is what i did on my fox mustang that was running low 12s on the t-5. i belive that mo will have no problems with brakeing a t-5, unless he gets pretty hard core about drag racing, wich i can see him doing. but we will deal with that when it happens.
  9. 302-72-mav
    302-72-mav Member
    sactown CA
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I appreciate the advice and I'm sure you're saying that to keep me from wasting time and money. You know, what I was envisioning for the mav was so different until I met Bryant. It's great talking to him, it's just so many options out there which is why I have changed my ideas around a lot. I'm still learning a lot and so I think I'm gonna change my mind a few more times till I find the perfect thing. But I don't really go buying something before I decide for sure (only mistake was those pistons which I bought for a higher compression 331, anyone interested?)
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this is the break-down by 302-72-mav:
    t5 trans and bell-housing
    87-93 mustang clutch/pressure plate throw out barring pilotshaft barring and flywheel can get it as kit on ebay for cheap i got the f1 stage 3 center force one and it works great
    157 tooth flywheel with 28 or 50 oz counter balance weight depends on what year motor u have ?
    the clutch pedtal
    i made a (trans brace) with the stock one and some extra steel
    i wanted to shorten my driveline because it was kinda close so after 4 months of driveing it just decided to get it shortened 1 inch cost 60 buck's
    i think thats it
    and i used the same starter
    there is a bunch of pics of it here
  12. tody
    tody Member
    cologne, germany
    might be, could you pm me details?
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I think this T5 thing might actually happen. Several reason why I want to do it. I have never owned a stick shift car. Back when I lived in LA it would have been tough commuting with a stick shift. Here in San Diego it's not bad at all. I want to be able to run lower RPM on the freeway and still have the option of switching to lower gears later if I decide to do so before going to the track.
    Gonna start collecting parts once I have money again. Picked up extra shifts for december and january. :)
