im trying to get my V8 swap mav fired up...
Discussion in 'Technical' started by newtoford, Aug 14, 2008.
  1. Dave B
    Hey, thats too easy of a question to ask!!
  2. newtoford
    newtoford Member
    New Castle Delaware
    no, not yet...
    gotta take the header off first :banghead:
  3. Dave B
    Drop the idler arm and pull the steering down, then you shouldn't have to pull the header.
  4. 71gold
    his will if the motor's locked up...:yup:
    yours would if it had some compression...:yup:
    ...DFF...
  5. newtoford
    newtoford Member
    New Castle Delaware
    if its not the starter locking up the flywheel i cant really thing of anything else it could be thats NOT serious
    even if the pinion is engaged i should still be able to spin her one way right?
  6. Dave B
    :cry: Why do you have to be like that?? :cry:
  7. Mavman72
    If the starter locked up(probable) that engine wont move.You could try whackin the starter with a hammer first to un-jam it.Otherwise pull it...Good luck
  8. PaulS
    Pull the starter and check to make sure it is for your transmission - autos and manuals use different starters.
  9. newtoford
    newtoford Member
    New Castle Delaware
    how will i know?
  10. blugene
    Not sure how you will know but just loosen it and whack it with a hammer. You shouldn't have to "remove" it.
  11. 71gold
    i saw a sticker on my H/T starter the other day that stated...
    WARNING.."Do Not Strike With hammer"...:yup:
    i thought it was strange for them to make a sticker just for that warning...:huh: ...it must be a no..no..:yup:
    ...:Handshake...
  12. Dave B
    So whats the action today???
  13. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    actually you can get the starter on and off with pinion arm in and header still on :p
  14. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Just joining the thread, but im guessing bad starter also, had this happen once, and thought I had tore up a motor severely.
  15. PaulS
    Those high torque motors use permanent magnet fields - hit it with a hammer and those puppies crack into pieces. I have replaced more than a few of those magnets in electric motors and I can tell you - don't hit the starter with a hammer. If it is locking the engine up then the starter drive is bound - not the starter. just loosen the bolts and see if you can move it - if not then remove the bolts and you can free it up.
