Image help
Discussion in 'Technical' started by Bioinfomatic, Mar 8, 2008.
  1. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    1974 Comet Gt 351W T5 8.8 .520/.545 hydraulic cam 1 5/8 headers
    where did you get the measurements from?:)
  2. Bioinfomatic
    Bioinfomatic Member
    Philadelphia
    1977 Ford Maverick
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    A 3.75 Backspace wheel will fit but i really don't think you will be able to stuff a 295/50 under it with a stock wheel well configuration.Thats a big tire! If you really like the wheels get them and look around for a worn out tire at a tire shop just to try on there to see if it will fit.
  4. scooper77515
    That is why my front tires are not matched. I originally worked on the back and found some BFG T/A 245/60r15 and liked the way they fit, but thought I could squeeze in a little more. So I got 255/60 next time. Little rub on the fender lip, but corrected it with my Cal-Tracs.
    Then front wheels i tried 195/60r15 and way to skinny, and too low, and headers hit the ground on every bump. Now trying out 215/60r15. Much better. and I will probably keep this size when I buy new.
    Each used tire has run me about $25 each, and I got about 3000 miles out of the rear one before teaching my wife how to burn out. I also have about 4000 on the fronts, and still much wear left.
  5. 74CometGT351W
    74CometGT351W Dano
    Marion, NC
    I agree, that's an awful big tire. maybe a 255/60 or possibly 275/60:)
