In Tank Pump For Forced Induction
Discussion in 'General Maverick/Comet' started by 71maverick361, Aug 29, 2016.
  1. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    My Phantom will be here tomorrow so going to do the install this weekend
  2. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    Just make sure you know where your outlets for the pump are going to be. I had to clearance the trunk a little
  3. 71maverick361
    Odem
    71 Grabber
    I am hoping to run my lines the opposite of yours down the groove already in the tank toward the front of car
  4. 7D2 Grabber
    7D2 Grabber Member
    For some reason my fittings would hit, I used -8 for the feed line. If I was to do it again I'd stay with -06. Amazon has good deals on the black aeroquip lines for those that are looking.
  5. 71maverick361
    Odem
    71 Grabber
    Yeah Aeromotive want you to use 8an = 1/2 for feed and return but I would rather use 6an = 3/8
  6. 71Mavrk
    71Mavrk Member
    Nevada
    That is how I did mine:
    Micah
  7. klsanders
    klsanders Member
    Alabama
    looks great! what did you use th
    Looks Great! What did you use the carriage bolts for?
  8. 71maverick361
    Odem
    71 Grabber
    71Mavrk. What size line did you run ?? Looks like 1/2???
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Wish I could say I remember, but I don't. Probably 3/8.
    Micah
  10. 7D2 Grabber
    7D2 Grabber Member
    I replace the tank strap bolts with longer carriage bolts.
  11. 71maverick361
    Odem
    71 Grabber
    So what did everyone do for the vent?? Did you use the factory line up to charcoal canister ot a after market vent??
    Thanks
  12. 7D2 Grabber
    7D2 Grabber Member
    Aftermarket vent attached to the highest place you can get it [​IMG]
  13. 71Mavrk
    71Mavrk Member
    Nevada
    I connected the Tanks Inc. pump vent to the original canister.
    I no longer have any issues when I fill up. No puking gas out the filler tube. The original vent appeared to be plugged.
    Micah
  14. 71maverick361
    Odem
    71 Grabber
    Got it installed
  15. 71maverick361
    Odem
    71 Grabber
    Did anyone coat there new tank on the outside ?? Also dos anyone have to use the foam on top of tank for spacing ??
